Djfknwoo
Hey guys I've tried searching the forum about this issue and I have a couple questions. I just got my bike running and I'm finding after it's parked i have a few drips of oil coming off either the sump bolts or from the 2 acorn nuts from the bottom of the engine.
I'm pretty sure it's not from the sprocket or the starter gear cover as the only place I see the oil coming from is below. There is normally just a couple droplets after it's been run.
A bit of information about my bike is when I changed the sump filter I had my torque wrench set wrong and might of over torqued one of the bolts but I'm not entirely sure as I noticed pretty quick and the bolts never snapped (stock bolts) and the treads on the engine seem to be okay as the bolts still go on snug and don't just spin. I have installed a new sump filter and gasket and new crush washers. Does anyone know what it could be or if I should take the sump back off and potentially look for the raised aluminum around the threads? Or if I should add grease to either side of the sump gasket and if so what grease would be recommended?
Thank you all in advance
