D3viousd4n
Hey again everyone,
This is a follow up to my previous thread about swapping my 1978 XS650 from a PMA charging system back to a stock system. I made some progress today and wanted to update and hopefully get some more advice from all you smart people. I might be a little long winded here, apologies in advance.
From where I left off I had wired the connector plugs between the stator and reg/rec unit. Today I removed the PMA and installed the rotor I got from @Jim. I made sure to grease the crankshaft and keep the woodruff key in place, and tightened on a new washer and nut. I was unable to find the proper mounting screws for the stator housing, which are 6x75mm. Instead my local hardware store had 6x70mm and 6x80mm. I bought a pair of each and found the 70mm too short and only able to catch a couple of threads. I went ahead and installed the stator using the 80mm screws. I did notice a gap between the left and right tabs of the engine and the stator housing that look like they want to be touching. (See image) The middle tab touches but the left and right ones do not. I also found that the rotor spun with a lot more resistance with the stator housing on. Let me know if any of this sounds problematic.
I also had some issue routing the stator wires through the plate by the front sprocket. (see image) is there a trick to this? I did notice a bolt towards the rear wheel that seems to hold the plate in place, but I’m not sure how I can access it. Do I need to take the sprocket and/or chain off?
I mounted the reg/rec upside down and underneath the battery box. @650Skull pointed out that I should not mount the unit to the battery box due to it not being grounded—my understanding of this was that it was assuming a stock battery box. The battery box on my bike is custom metal and bracketed to the frame with more metal, and so mounting here should not be an issue, correct?
I took a look at the harness and could use some help identifying where to attach the brown wire from the reg/rec. There looks to be a brown wire coming out of the ignition switch, connecting to a red wire and then connecting to the starter relay. My impression is that this is where I need to work, but I’m not sure exactly what to do.
Lastly, and what I’m most embarrassed to admit, is that this whole time I had assumed I was working with a points ignition system without actually having checked. Well, today I went ahead and took off the plates and found an electronic ignition—all in all what I should’ve expected considering the system that was already in place. Can I still use electronic ignition with a stock alternator and solid state reg/rec, or do I need to go about buying more parts?
My plan is that once the charging system is sorted, I’m going to do a cam chain adjustment, valve adjustment, and then set ignition timing.
Again, sorry for having so many questions and thank you to everyone for all your input on my previous thread, I really could not be doing this without all your helpful guidance. I took a lot of photos while working today, hoping they’re a useful reference.
