HI Fred, thanks for the reply. I do agree the designer was having a bad day. I read a number of your posts on the forum, clearly you share your knowledge with all...hats off to you. I didn't see the one about the 100' black strip though...hard to watch that when its your son. We made a tradition of riding on New Years Day here in these mountains. Lastt year a riders son went down on black ice...nerve racking for the father. But only small damage to the bike.
On the fix for the SA, yours is certainly robust. I think part of the problem (other than a poor design) is that when the SA assembly does not mate up closely to the frame bosses, the frame has to be squeezed to apply enuf pressure to prevent the tube from rotating relative to the frame bosses. This means the frame bosses are no longer face parallel to the seals and a bending force is applied to the pivot bolt. That bolt we all know is weak due to its diameter step at the thread ends and that it is hollow at the same point. Keeping the faces of the bosses parallel to the faces of the seals will eliminate a bending force on the pivot bolt at the thread ends. I think shimming the gap is a good idea because it keeps the tightening force on the pivot bolt aligned with the centerline of the pivot bolt. My guess is that's what has caused the many failures of the pivot bolt.
