Kopcicle, Many thanks! Got a couple questions though: Actually, this first question applies to both the GM and Chrysler units. I'm pretty familiar with the Chrysler unit, having had 33 years in the field for Chrysler and 3 of those were in the '70s as Chrysler Field Service Rep. I've often wondered about 'converting' an automotive ECU to motorcycle use......as they are pretty reliable 'switching' devices. But, I know for a fact that there are NO advance curves built in to the Chrysler unit. The Chrysler distributor, much like the OE Crank-Based unit, simply derived it's trigger signal from a 'star' shaped device (Reluctor) having points that equaled the number of cylinders.....and as each star tip passed over the pick-up coil a signal was induced that then triggered the ECU. BUT.....the old style EI systems still relied on a mechanical/vacuum advance built into the distributor.....much like I believe the Pamco unit does using the original Yamaha Points system centrifugal advance unit. So, in adapting either the GM or Chrysler unit for use...and assuming you're still using the crank-based pick-up system....how do you account for an 'advance' program? Or, if using a different pickup with the automotive ECUs.......aside from the Pamco unit.....do you have a different method that DOES supply an advance?
I guess the other question is simply; What about other motorcycle ECUs that might be applicable......like an adaptation of a 400 or 750 2-cylinder with electronic ignition......or even a Honda, Kawasaki, or Suzuki unit that might have some similar engineering?
You mentioned Briggs & Straton; I have wondered about those myself. But, again, not sure how the programming works......and what kind of advance system is employed on some of the Briggs units. Also, wondered about the HD systems. Harley's been using 2-cylinder electronic ignitions for decades, and the number of after-market units available to 'upgrade' a HD is amazing. My HD has a unit made by Daytona called a Twin-Tec. It's quite programmable......had a cost of about $60 when I purchased it.......and it works with HD's single wind / dual fire coil.......which is a similar design to Yamaha's coil. I gotta believe that there's some potential there for adaptation.......but have heard of no one ever giving it a try. Just seems to me those are better options than attempting to re-purpose the automotive units that have the 'no-advance programming' associated with them. But.............hey, I'm a rookie at all this......so that's why I'm asking the questions. There's probably good reasons....and I'd just like to know what they are.
Tom D....... (2 cats by the tails.......lol)
