But I guess you knew that.
sorry for stating the bleeding obvious
I hadn't seen it .
Very happy and excited to see it and and see this reluctor setup work. Dennis had been advocating for this setup in 2007
Great to see In this video that the (in my case MoPar) pickup works with reluctor I'm using (all but 2 180 deg apart of the cogs ground down) makes enough output at cranking. I had given up on this approach from fear and loathing about enough pickup output at kickstarting speeds.
to find out another OEM source.
He used the Lucas backing plate modded to fit in the 650 housing
Lucas oem Rita
Some Volvos used a Rita System and I wonder if Lucas used a off the shelf from Borg warner or bendix part
americain (mopar. lx109 single pickup
LX114 dual pickup 277 ???
Before I finished this reply I went out to start to setup a test to see if I can repeat this video with the Gonzo.
First step mod pickup mounting base to ~2" diameter.
