The first time I removed the left spark plug, it came out hard. The threads in the head were damaged. I dug out several broken thread pieces.
I bought a cheap back tap thread repair tool on Amazon, which clearly was defective, so I never used it.
I then bought the most expensive branded back tap tool on Amazon, sold under the Powerbuilt name. The cheap tool was $10.90, and the Powerbuilt tool was $24.87, to my door.
In my pics you can see that the cheap tool arrived already expanded, even with the expander plug fully disengaged.
The Powerbuilt tool worked great.
The Youtube videos I watched were fairly useless. All the instructions that you need are on the back of the Powerbuilt tool package (above). (The cheap useless tool came without any instructions.)
Couple notes: the instructions say to make 2 - 3 passes, incrementally expanding each time. I probably made 10 passes, and I'm glad I did. I hit a couple of very hard spots on each pass.
The instructions say to "insert" the tool all the way in, completely clearing the hole threads. You will find that you don't simply "insert" the tool -- you have to thread the tool in. It will thread in with very minimal resistance, even past the damaged areas. Then, you expand the tool, catch a thread in the hole and back it out. After my first two passes, I learned that when threading the tool in, you could feel just before you are about to completely clear the hole threads, and that is when I stopped inserting. This sped things up, because you didn't have to carefully catch a thread -- the tool was already started on its back-out chasing pass.
Most importantly, I wish I had stopped making my incremental passes before I had fully expanded the tool. In other words, I wish I could take back my last two passes. The reason is that the finished chased threads are very loose -- sloppy even. I think that if I had stopped sooner that I'd have a better fit and that I'd be happier.
Now you have to remove the residual swarf-laden grease from the hole. Cotton swabs were fairly ineffective. What worked well was a very thin wire-bristle bottle-brush with a piece of mineral spirit soaked cloth wrapped around it.
After. I should have taken a "before" picture. Looks pretty good considering that it started out all screwed up.
Spark plug holes have a small, very slightly raised lip at the top. My lip has a missing area (red arrow). Not sure what's up with this, but I'm going to keep an eye on it. I can envision fuel/motor oil working its way up through my loose threads, and leaking out this gap.
