More rear fender damage. The large hole on the left is for the seat stay (the "grab hoop"). They are always wallowed out.
The small hole on the right with the cracks is the upper taillight mount hole.
(The hole in the middle is for the taillight wiring harness.)
Made a repair for the seat stay inspired by this post from Gary:
https://www.xs650.com/threads/home-market-tx650-going-to-soir.66443/page-4#post-844552
Only I don't weld, and I was in the middle of glass work, so this will be a fiberglass repair.
Found the perfect flanged collar, just needed to be shortened.
Flanged collar in place.
Also, using a fender washer to repair the cracked taillight mount hole.
Repaired, I just need to drill the fiberglass out of the holes.
The brown color under the glass is putty that I made by adding flocking to resin, in order to level the surfaces so the glass mat would lay flat.
There are about 10 layers of alternating-orientation glass mat.
BTW, you will note the large fiberglassed areas above and below. The one below is my previously described large crack repair. The one above is a preemptive repair -- it looked like a similar crack on that side was imminent.
The fender stay appears to have been re-chromed, but no one ever bothered to chase the threads on the mounting post afterwards. Instead, they just jammed an SAE nut on.
A great many parts on this bike have been re-chromed, and it's held up very well.
Sort-of-rant: the whole rear fender and seat stay scheme is by far the weakest design point of the early bikes, in my opinion. That single M6 stud in the pic supports most of the fender, and all of the taillight assembly, which is cantilevered out from that stud. The mounting system on the other (front) end of the rear fender is janky and somewhat ridiculous.
It's no wonder that those stay mount holes in the fender are always damaged, and that the fender often has cracks.
Chased the stud threads.
Because of the build-up from the flanged collar that I glassed into the fender, I now need a slightly longer post and stud. Accomplished both at once by taking an M6 coupling nut (left), and grinding a section of the points off (middle).
Here's what it looks like in action.
Left: collection of damaged dampers that slide over that post, and one in the foreground that is still usable.
Middle: gauge mount damper assemblies from 1976-1983 XS650s. One of these dampers usually works pretty well on a slightly worn-out 1970-1973 fender and fender stay set-up.
Right: but neither would work for me. I built-up a damper using a piece of tubing and two inner tube rubber washers.
Here's the final part set. The length of the coupling nut has been trimmed down. Compare to the parts diagram, and the only thing that's missing is the lock washer, part # 19. It's diameter was too great to fit inside the damper tube. I used Loctite instead.
I am very satisfied. The fender is very securely mounted, yet still has vibration dampening.
