I certainly don't want to be an armchair critic and I hear that you are thinking all these considerations through. I agree that it can be a challenge to find a good location for a remote filter. Carry on, enjoying watching your build!
The smaller filter is a better fit. If I remake the adapter I can get it 1/2" closer to the engine and maybe 1/2" higher.I certainly don't want to be an armchair critic and I hear that you are thinking all these considerations through. I agree that it can be a challenge to find a good location for a remote filter. Carry on, enjoying watching your build!
It is a fit issue. The adapter clears the motor mount by less than 1/4". I tried fitting the stock filter and it will not fit.Just curious why the stock filter is unsatisfactory, doesn't look to be a fit issue
Oil flow is pretty simple, theres pictures showing the inlet port further up the thread, so that feeds oil into the filter, it flows throughthe filter then up the center. The green bolt that holds it together has holes in it to allow oil in, to flow back into the motor.IF you remake the adapter, and you don't plan to reuse the first one you have here, I'd be interested to see a sectioned side view of it, the way the oil flows thru it.
If I had a tank that was close to the right shape I'd consider it. It would be easier to do a little reshaping compared to forming it all. I'm sure with experience it gets easier, but it'll be a long time before I'm close to someone like Ron Covell.
It is on SOHC4, but it never gets much engagement from members there. The honda 4 people on forums and facebook definitely act like gatekeepers and get offended when you ask anything that goes against the norm on basics. Ask about wossner pistons,"why would anyone run anything other than wiseco!" Ask about an ignition,"why would anyone run anything other than dyna or stock points!" And in depth engine questions tend to get answered with, "just call cyclex, they know all and are the only authorized purveyors of info."Simple, albeit innocent question... why isn't "The Norda" on a site like SOHC/4, rather than XS650.com?
Same reasons we also post about making our own Sauerkraut or things like that.Simple, albeit innocent question... why isn't "The Norda" on a site like SOHC/4, rather than XS650.com?
Too far away to be a good deal. Almost 4hrs each way according to google maps. It would need to be extremely rare or an extremely good deal to go that far.
Half the "sandcast" bikes don't even have the original sandcast cases. They got replaced by a dealer due to chain breaks. The engine I'm using is a 74, definitely not sandcast and I only paid $200 for the entire cb750.Unless it's a pre CB750E-1007414 VIN, one with the earlier sandcast cases. Looks no better. Is no different. Rides no better. Isn't particularly rare (a bit under 2% of production, 7414 units). Just a massive$$ premium to be in the 'Sandcast Club'
