The Norda
I think the middle mount on the frame will have to come off. But it looks like it'll be pretty easy to get the motor in.
Gotta wait for sprockets, swingarm pivot bolt and make a rear axle to figure out the final location.
Cannot see .. are there any radius at the diameter changes on the axle
If it is sharp I don't think it is best practice . No idea what it is called in English
Stress concentration ? .with higher risk for cracking there .Can be a safety factor
.032 radius in the corners. It's easy when the cutter has the radius on it.
I think this is about where the motor will sit front to back, side to side will be dictated by the chain. The output shaft is pretty close to even with the swingarm pivot height wise.
Any further forward will require a remote oil filter, it's already going to need a spin on conversion. The stock filter housing is too wide to fit between the down tubes.
As you can see I made some spacers the same length as the cylinder height. It lets me put the head "on", while keeping with weight down.
I did some reading and found that on average the front sprocket on a triton sits about 7-9" ahead of the swingarm pivot. The variance is due to pre unit vs unit and long vs short chain case. The cb750 puts it about 5 1/4" ahead of the swingarm pivot. So front to back distance is pretty good, still waiting on a swingarm pivot to set side to side.
You think that 1/4” is thick enough? Those are some long plates and the motor will be flexing them
I've got the templates for a preunit triumph into a featherbed, they recommended 1/4" and those are way longer and skinnier. Once I have it mounted I can always add bracing, but with the front, and middle mounts I don't think there will be much room for flex.
The granite is on there so the frame doesn't fall backwards when I pull the cases out. The rear hub is heavy enough to tip the whole thing back.
Suspected that it was there as ballast of sorts. Wouldn't want it to fall though! Just acquired a very similar surface plate from a friend whose FIL was a machinist with a whole hoard of interesting tooling and whatnot.
