The Norda
Yeah. I would love a bigger more rigid lathe, but they cost big bucks. I only paid $500 for the atlas with 3 jaw, 4 jaw, faceplate, milling attachment and a few bits of tooling. As long as I stay within it's limits, it's great. Right now I'm getting less than .001" of taper over 12".
My Atlas is the same. For parting I'll either use the tool post grinder and a cutoff wheel or throw the part in the chop saw and face off the rough...
Yep, parting is the bane of any small lathe. I did manage to finish 90% of the steering stem today. I'll take it to work where the lathes have a big enough through bore to drill and tap the end, as well as face the bottom.
I did sneak a XS part in. I'm using the lock nuts for an XS since the size works out perfect at m25x1.
Sounds like you got a somewhat better deal I got on my Logan; $500 with a 3 jaw, a scrap 4 jaw, lantern-style tool-post and a full complement of Armstrong tool holders, a turret tailstock, no motor but a mechanical hacksaw came with the lathe as a package.
How are you doing the metric threading; does your lathe have a set of suitable change gears or are you using a die?
It doesn't have a quick change, it's open the side and read the chart to see what gears go where. I had to buy a few extra gears and a hub to actually set it up for metric. Biggest thing to remember is don't turn the feed off when doing metric threads. Back the cutter out, switch the motor to reverse, and repeat.
For what this is worth, I saw in one of your earlier posts you had a knee mill. You could always bolt a 3-jaw chuck to the table and use that to hold round work.
Please tell how you use it I have not had great success over the years
Possibly via using the wrong method
Better when I apply torque counter clockwise on the wrench before hitting
The latest I have was higher priced and can be better
Are you tapping it or smashing with force ? Large or small hammer ?
Should be outlawed those screw heads
I avoid the manual impact wrench and use “air gun” impact wrench, it seem to work much better for me
The M18 impact gun has been a game changer for me.
I've got a m12 impact. Very useful, but when I'm dealing with already half stripped stuff I prefer the control of the manual impact. Plus I bought a 10 pack philips bits for the manual, so I can grind the tip down to get the best engagement possible. That probably helps as much as anything.
I've got a rotary table and manual indexer for the mill. Both useful for doing hole patterns. But long parts can be a real hassle on the mill.
I'll try to take a picture of the setup the guys use as work for drilling centers in long shafts before they go into the CNC lathe. It's basically a vise hung sideways off the table on the Bridgeport, and the other end of the shaft can go all the way to the floor. It's pretty ingenious actually.
Just riffing, derailing... When forced to mess with a fubar phillips (JIS #2) reforming the head with a center punch between the slots then hammering in a bit before turning often does the trick. As always alternate tighten loosen efforts til it breaks free.
If it's really bad straight slotting the head with a thin disk in the dremel.......
Manual mills are really flexible. I've done similar to drill new holes in a mount stand. It was actually tall enough to sit on the floor and the vise just held it in place. It just gets to be a hassle to move the head, then move it back and re square it.
Yeah, there's a lot of different tricks out there. Some of the screws on the cb750 engine were pretty bad.
