The Norda
Made new pins. I did scrap 3 of them, the 1.2mm drills are rather fragile. Had much better luck once I changed pulleys on the mill and ran a little over 2000rpm.
Managed to find all NOS brake cam arms for less than it would cost to rechrome the ones I have.
Some of the linkage pieces I made are now available on ebay, they are proud of them, making my own was a good choice.
I also bought an oxy acetylene torch at the swapmeet today. Got it for a good price, so now I can start thinking about trying to make a fender with the english wheel.
"Torches vary wildly in price around me. Mostly from high, to I could buy new for that."
Here in Montreal you have to rent cylinders unless they are the smallest ones, which you can either own outright or rent. I have the small ones, which I own. Got my oxyacetylene torches, regulators, the small bottles and a cart from a neighbor who was moving, in a hurry, I think! He wanted $25, which struck me as reasonable under the circumstances ;).
That's a deal. Here I can buy and own just about any size bottle. But space and cost are a consideration.
Yeah, me tooooo.:rolleyes:
I like the Short Circuit Manx tank...:twocents:
I'm leaning towards the mini manx tank because it has a little more bulk and the cb engine is bigger than the norton or triumph twins. Plus I do have the 43mm forks, so the front is a little bulkier. I do like both, but with the cost only 1 will be bought.
Here's a pic of the one cb swapped featherbed I found online. It's got a manx style tank, that's part of what has me leaning towards it.
Haven't done much lately. Waiting on parts and funds. Ordered all transmission bearings for the motor, ordered a mini manx tank from TAB classics it's in works but has a lead time since they are hand made, and started working on a headlight mount.
Started with cheap china headlight mount, mainly for the fork brackets. I can make it all but when brackets are $20 it's not worth it. They put the light too far forward and too low, so I started prototyping new arms and settled on 2" back and .8" up. I'll make a drawing and cut them out of aluminum next.
Got some cheap shocks to have something better than zip ties to hold the swingarm up. Also to check and verify the chain won't hit anything.
Next I plan on setting the head back on and installing carbs so I can plan the oil tank and check fuel tank clearance. So I'll need to buy carb rubbers soon.
