maverickbluer1
Okay, thanks for that. I did swap out the 2mm washers, but it didn't seem to help. I'm wondering if this clutch boss could be worn down. I don't know anything about the engine. I bought it for $300 on eBay. It doesn't seem like the last 2mm washer fits flat on the thrust washer. It kind of rocks back and forth when you push on it. I found a NOS one for a reasonable price and thinking of buying it. WDYT?I think that star shape is just the outline of the steel splined insert that's fitted into the aluminum hub. Did you confirm washer thicknesses? The two large 2mm thick washers are the same and could be swapped (2nd and last washers in your pic). Maybe things would fit better that way.
