Howdy,
my question is: what is the timing curve for this 650 motor?
To elaborate:
My 1975 XS650 seems to be lacking power until I hit about 4,000rpm and then it wakes up and pretty suddenly. So it is not a gradual power increase.
Carbs are good and she runs like a raped ape above 4k.
I just checked timing. At idle, the timing mark aligns with the F maks and when I increase RPM, the timing does not advance until close to 4k when it quickly goes to full advance. I wonder if that's the culprit.
Hence my question above: what is the timing curve for this 650 motor?
The MM gives me specs on base timing and full timing but does not mention at what RPM the timing should be fully advanced, nor does it show any timing curves/graphs. I did not find anything here on this forum or in online searches either.
Naturally, I will be removing and cleaning the centrifugal weights in the timing advance system but I would still like to know the spec so that I can make sure that the advance kicks in correctly.
Thanks a lot in advance (pun sure as heck intended! )
Lou
To elaborate:
Lou
