I've seen a number of different ways that members here balance their tires so I thought I would share mine. The type of balance "stand" was talked about on the BMWMOA forums years ago and seemed like a good idea so I made a set. The main advantage being that they are small, easily portable and flexible enough to be setup almost anywhere. That said,I have never taken them with me or had a need to take them anywhere and probably never will. It would be quicker to setup if I had made them to fit on top of a couple of jackstands. I threaten to modify them to do that every once in a while, and if I used them once a month I probably would but I don't so I just keep using them the way they are. The bearings are 1' O.D. and they are mounted to a piece of 1/8" thick aluminum, both from McMaster.
They are suspended from just about anything horizontal and reasonably strong, you could even use a tree branch on the side of the road to do an emergency tire balance.(could happen???)
I like the stick-on wheel weights from NAPA. Depending on the wheel they can either be cut off and pushed down firmly (if the surface is slightly curved) or formed around the OD of the appropriate socket (for more curved surfaces) like I did for the shouldered rims on the TX.
Just thought I'd throw it out there since I was balancing the tires on The Parts Bike today.
