rickthefix
I've tuned quite a few carbs over the decades, so not a newb, but these are different than the 77 to 81 XS carbs I've worked on.
I'm guessing here at the moment, so corrections please if needed and maybe actual correct steps.
Sync'ing is easy, have my baby bottles set-up for that. It's the other stuff I need info on
I'm seeing "air" screws on the sides right by the intake boots.
Then there's the brass plugs underneath that have probably not been removed before? Assuming this is the factory air screw there.
Thinking I'll leave the brass plugs in since it seems to run pretty well.
That leaves the air screws on the sides.
Warn up to normal op temp, turn off the fuel to the right carb and let it run out of fuel.
Run the idle up to 2k on the one running carb.
Adjust the air screw until it runs the idle up to highest point then back off the screw 1/8 turn or so.
Then do the right side.
Then sync them.
Does this sound about right?
Then sync them.
