Turn signal issues. Any ideas?
Dio77
Rubber side down
Dacono Colorado
So I’ve been having some right turn signal issues. Left works fine the right doesn’t. I’m thinking relay?? Need somebody with a bit more knowledge for some advice so I’m not just tossing parts at it. I tried to attach a video but I didn’t let me. Thanks for the help
If one side blinks, then the relay/flasher is fine. I had the very same issue with the turn signals on my '79, the left side would occasionally blink, then stop and the right side wouldn't blink at all. The problem turned out to be the wires inside the handlebar switch had become unsoldered. Apparently this is a known issue with these bikes.
Check the switch, power in should be line voltage (around 11.5-11.8 VDC) and power out on each side should be the same. I disassembled the switch and soldered the the wires.
You’re the second one that has suggested that. Think that’s where I’ll start. Thanks
