TwoManyXS1Bs experimental clutch
EarthHeavy
Charleston SC
Hey guys, I’m going to do TwoManyXS1Bs experimental clutch mod according to his v2 instructions. The question I have is this will be going on a 447 with shell #1 cam and 750 BB kit - currently I have the 8 plate clutch upgrade installed to handle the engine mods. With the experimental clutch it’s designed for the 7 plate version, which i have no problem going back to, but…
Can ya’ll recommend any specific fiber plates and springs that will handle this engine with the 7 plate clutch? I have Vesrah springs installed now and have an easy lever pull with them -I am thinking the next step stiffer will compensate enough not to slip. Any thoughts? Thanks for reading
I have had good luck on 3 or 4 bikes with Barnett Kevlar friction plates.
As for springs, the Vesrahs are a bit stiffer than stock, as are the EBC's. At the top end are the Barnett springs, but they are crazy stiff and I wouldn't recommend them (I bought them, as I'd had good luck with Barnett springs in the past, but when I got them and saw the extra length and the apparent spring rate, I bailed and bought the Vesrahs). I think I also remember reading someone (maybe MMM?) talking about the stiffness of the Barnetts adversely affecting the actuator.
Edit - PS, if you want to try the Barnett springs I'll see if I can find them... they're yours for the asking if I can find them.
