BoatBiker
XS650 New Member
Hello all - brand n00b here, looking for ancient wisdom of the 1970s...I have recently acquired a very nice original condition TX650 - all there, great paint, great chrome, and ran great once it had a new battery and fuel. Unfortunately, while riding last week (have put quite a lot of miles on since aquisition) it suddenly began to stutter and cough and miss. It feels like it isn't firing on every revolution, on at least one, or both cylinders. However, the bike starts, idles and revs (in neutral) just fine, but has zero power once you put it in gear and try to pull away.
I cleaned plugs, which had a little carbon but were in pretty good shape. I put in new plugs and new plug wires but not caps [couldn't find any in my little town]. Runs exactly the same. I had a suggestion to check the coils' resistance, and I find that on right I have 3.9 Ω on the primary side and 8600 Ω on the secondary [which I understand is normal], while on the left I also have about 8500 Ω on the secondary, but only 2.5 Ω on the primary. Could this be the cause of the misfiring? I found a lot of info here on what the resistances should be, but nothing about what the symptoms might be of low primary resistance numbers...(All ignition components appear to be stock, points are in great shape.)
To be honest, I am not even sure that this problem is caused by elec rather than fuel issues, but I thought I would check basic elec components before tearing into carbs...Thanks in advance, J
) and it sounds as though you have eliminated most of the electrical issues. As I understand it, the engine did run well - but now does not rev-up under a load - although it does start and idle satisfactorily.
