Jfl0528
Cool guy
AgreedLots of ifs and buts but engine comes apart regardless of oil added or borescope or inspection through small holes.
$300 is a good start. Maybe suck it up.
thank you I will rebuildI would certainly fix it if it were up to me. I have 2 XS 650's, one I did a budget rebuild on for about 800 bucks to get it into rideable shape and the other one is complete for parts but has major issues to get it running again (needs crank rebuilt). I have about 1800 in the rideable one and it is a hoot to ride. It had cam installed incorrectly when purchased, causing bent valve and broken valve guide therefore causing it to be parked in 1984 and never touched til I bought it with title for a whopping 75 bucks. With much elbow grease and a decent chunk of change thrown in, I had a running bike. So if you are mechanically inclined, you should have no problem.
Are you capable of starting a project and seeing it to completion? You know yourself better than we do. Do you enjoy this kind of thing? It's not that expensive as hobbies go. How much it's going to cost depends upon you. That thing could end up $2500 or less, or four times that. It's a matter of where you want to take it. Enjoy the journey. Share it with your friends at XS650.comthank you I will rebuild
True... but these things are pretty simple really I think. No emissions crap, no fancy computer controlled fuel injection. Carbs and a charging system really. Once you have a handle on those two things most everything else is a cake walk.100%! But their big argument is that I can buy a running bike for the cost of all the parts
Looking at the pics, I agree with @JOHNDADDY ... looks like that left exhaust valve hit something. Everything else though looks pretty normal for a well used motor. After you get the valves out, we'd like to see closeups of the valve face and it's seat. Hopefully they can be reworked.Here we are as of today, it looks pretty bad,
No marks that I can see, I’m getting a quote from a machine shop today to see what he’ll charge for a resurface, on one side I poured water in the combustion chamber with the spark plug in and it leaked everything out immediately, hence the zero compression, the other side leaked while giving it compressed air. Both sides need workIs that a dent in the top of the left exhaust valve?
Any marks on the pistons showing collision?
Can't really tell with my eyes. lol
Timing's easy, no worries.
Where did it leak from?on one side I poured water in the combustion chamber with the spark plug in and it leaked everything out immediately,
Unfortunately no, wipers weren’t wiping. Rings are frozen to the pistons.Some carbon there but over all OK
I wold have oil on top of the pistons lubricating downwards
Maybe a lapping of valves can be enough
Out of the exhaustWhere did it leak from?
Wow good eye, I have it right in front of me and I didn’t even see thatLooks like a tap on that exhaust valve
It's right here.I marked the bad side with chalk, I don’t see any signs of damage
Yeah, something has passed through there, it seems.
