Wrenchboar
XS650 New Member
Hi guys and gals,
I've picked up my father's XS 650 at the beginning of the year and started a quick tidy up of the bike as it has been repaired over the year with what was available 30 years ago in the middle of the French countryside without much money.
The main issue I had was about the front wheel, it was held together with the wrong spindle, wrong speedo cog and some shims here and there... then the hub seemed wrong as well, which I confirmed with some photos found here.
I since bought another second hand wheel for an XS 650 and it fixed almost all troubles, but I'm now stuck with a front wheel I have no idea from which bike it comes !
If anyone can identify it it would be helpful, below some photos and measurements :
The rim is a Takasago 1.85 x 19
The brake discs fitted on this wheel were the genuine yamaha xs 650, same bolt pattern.
Distance between the brake discs flanges : 85mm
Centre distance between the outside of each bearings : 92mm
Overall diameter of the hub : 148mm
The hub width is 55mm from the outside and 48mm on the inside of the perimeter spokes flanges.
Thanks
Thanks
