Unusual TX650 Clutch setup.
United Kingdom
Hi guys, I decided to put uprated springs in my clutch to try to stop the slipping, which is fairly bad, even though the clutch mechanism is adjusted such that there is a very wee bit of drag when clutch pulled. Took the pressure plate off and instantly noticed it was a 6 friction clutch, so though it might be worth sticking a 7 plate set in which, with the extra steel, only increases the stack by about 1mm (40 thou). However pulling the frictions out revealed something I haven't seen on an XS650 or any other of my previous bikes, namely a large grooved rubber ring per friction plate that sits snugly in the I.D of each friction plate. In section the rubber rings are a little like U channels. I'm guessing they are some kind of clutch grab reducer because being a wet clutch there isn't really any rattle to speak of, so thinking they aren't for noise reduction. Anyone seem these on an XS before? The 7 plate later model clutch plates are exactly the same footprint and I.D, so I'm guessing there shouldn't be an issue with fitting the 7 pack kit, other than having to re-adjust the actuator mechanism.
Hi guys, I decided to put uprated springs in my clutch to try to stop the slipping, which is fairly bad, even though the clutch mechanism is adjusted such that there is a very wee bit of drag when clutch pulled. Took the pressure plate off and instantly noticed it was a 6 friction clutch, so though it might be worth sticking a 7 plate set in which, with the extra steel, only increases the stack by about 1mm (40 thou). However pulling the frictions out revealed something I haven't seen on an XS650 or any other of my previous bikes, namely a large grooved rubber ring per friction plate that sits snugly in the I.D of each friction plate. In section the rubber rings are a little like U channels. I'm guessing they are some kind of clutch grab reducer because being a wet clutch there isn't really any rattle to speak of, so thinking they aren't for noise reduction. Anyone seem these on an XS before? The 7 plate later model clutch plates are exactly the same footprint and I.D, so I'm guessing there shouldn't be an issue with fitting the 7 pack kit, other than g to re-adjust the actuator mechanism.
cough zippytatoo 8 plate...........
The common consensus is throw the rubber plate separator rings away, IIRC.
Only 8 plate clutch kits I know of have thin frictions (IIRC), and I keep hearing rumours that they warp. Not sure if that's true though. But I'd like to give a 7 plate a try, seeing how I don't thrash my TX650. More like tootle around.
Coming back to those seperators though, what was their purpose? They just don't seem to do anything of value.
As I understand it, to assist in plate separation when you disengage the clutch. It seems their effectiveness is limited or negligible and as far as I'm aware they get thrown away the first time the clutch pack is disassembled.
Yeah standard plates AND springs, if you're not drag racing OR using excessive clutch slip to cover up for poor carburation.... :sneaky:
PS I have not heard of a single instance of warped plates from any of the many 8 plate set-ups I've supplied. That includes the set in the sidecar racing rig with several seasons under it's belt.
Hmmm, the chatter I've heard must be just that, idle chatter. Thanks gggGary for clearing that up, I did have my doubts about the likelyhood of warping. So, will ditch the rubber rings and stick the 7 plate set up on, with EBC CSK springs and see how it goes, and if necessary will give Heidens 8 plate set a go. Be nice to not have slip, my rephased 750 street scrambler slips too, and that has 7 plates and EBC springs, so never seem to get to enjoy the extra power.
If your 750 is slipping you might want to read this.
https://www.xs650.com/threads/upgraded-to-8-plates-with-ggggarys-kit.68150/
I've got his 8-plate Alto kit in 2 750s, neither one slips
Cheers GLJ, I've read that with interest. I do tend to hammer the 750 a bit, so perhaps I really need the 8 plate setup. The TX being a stock motor that I just cruise around on, like riding a lounge chair really, will hopefully be ok with the 7 and springs. Same goes for my newly built 277 750cc bobber/chop that will hopefully be on the road in a week. That's springers and hardtail, so a cruiser for sure, so again, hopefully, an EBC 7 plate and EBC springs will be ok.
Interesting, my 2005 K1200S BMW had problems with plate separation and the rubber rings were one of several things they tried without much success. Now you would think by 2005 BMW would be able to figure out how to make a good clutch that lasts but not in the 2005 K1200S. O ya I forgot to mention that you cant buy just plates from BMW,so you need to buy the whole clutch pack at over a $1000. Lucky several aftermarket companies do offer them for around $100 But since they have issues with separation the aluminum pressure plates wear out quickly. I do like riding the K1200S just not some of BMW quirks.
Now you would think bt 2005 BMW would be able to figure out how to make a good clutch that lasts
They did know how to make a good clutch, airhead clutches worked just fine.
They just decided what worked in the past wasn't good enough for the future.
And I don't mean just clutches.
