• It's time to vote for the bikes you want to see in the 2025 XS650 Calendar! Vote here!
vacuum petcocks
wheelsrus
central ohio
i have recently picked up a '78 with vacuum petcocks. i tried to read other info on them , not sure what the problem is with these. even after being rebuilt are they still not reliable? is the problem that somehow gas can still flood the carb? I have a 75&74 with regular ones should i just use that type? Thanks
I've been running the original vacuum petcocks on my '78 since I started running it back in 2005. They've worked fine. One did spring a leak, not from any of the rubber sealing bits but rather from one of the cross-drillings they plugged and epoxied. I fixed it with JBWeld.
