https://ebay.us/m/gS3MBm
By the way, I have the extra 4 left if anybody wants them…
PM sent.
Pete
No found this set in the bins so will use those.Have you actually looked into order the first type(captive ball type)? I believe they look like the same ones that I came across and tried to order,but the company didn't seem to exist. I thought maybe it was a scam or something. If you find out that they are available is be interested.if I'm not mistaken they fit the stock holes and threads where as the elephant feet (the second option) require drill and tapping.
That spec include bolts used as full time pile drivers? Asking for Madness sake.Hi Gary:
I put them in Lucille and since then I've put about 15,000 km (nearly 10 K miles) on them without problems. The need for valve adjustments seems to be reduced.
As for the reduced thread engagement - the rule of thumb is that anything over one diameter of thread engagement in steel (like the rocker arms) is OK. If the rockers were a softer material like brass or aluminium, you'd want about two diameters.
Anyhow, I looked at it and concluded that it is fine.
Pete
Ill take em. How much including shipping?View attachment 364298
How much for the 4 you have.
thinking about it and design variations!So Gary, with the stuff you listed, I assume you're going to try to make your own screws?
I am trying to install elephant foot tappets. It seems like the foot is to big though. I searched here for instructions but haven't found anything that had a clear process.are you aware of any instructions previously posted.Why are you replacing tappets you haven't seen yet??
Tappet and valve stem chipping is a thing in XS motors but they live on "just fine"
It does make setting valve clearance more art than science.
