Jtporter9
JT
Hi Guys
So I rebuild my bike recently, (first time) I got hoos racing cam shell 1, and 700cc JE pistons, got it all done, put together I adjusted the values, but tunning it was making a load ticking sound from the valves, but it ran decently well.
Then I realized that when I adjusted the valves I adjusted them with the opposite side on compression stroke, and not the same side I was adjusting, (making the backside rockers very loose) I thought adjusting them correctly by adjusting the same side compression side and so that the backside was tight against the springs would fix this. But when I went to start it my bike would not run, and there was still a loud ticking when kicking in the values and when i would rev it. (died at idle always) ,sounded like like the valves are knocking around.
So I thought I would check my cam alignment. When I did this through the cam cover on the left side of the bike the mark was about 90 degrees off, so I just tore it down again, but both my marks on the sprocket were maybe a link off but nothing major.
I am super confused as to what is going on. and thought maybe that I aligned the cam at tdc on the wrong stroke? is that possible? and if so what side of the engine needs to be on compression stroke when aligning the cam and how do I know what side is on compression stroke?
I could really use some help, this is my first rebuild. Thanks guys.
