Wasp-XS650
XS650 New Member
Hello,
I’m currently installing a new wiring harness in a WASP sidecar with an XS1B (447) engine. I’m planning to add a Koso speedometer and install an electronic Vape ignition
system, as well as LED turn signals and parking lights, along with an ignition switch. So far, so good.
The wiring harness that was previously installed in the vehicle was a source of constant problems and was therefore replaced with a replica wiring harness designed for the XS1B,
in the hope that the wiring diagrams I was able to find would match the colors. Unfortunately, that is not the case.
That’s why I’d be very grateful for your collective wisdom regarding the identification of the cable colors shown here.
In the middle of the harness, just before it splits off toward the wiring (?), there is a six-pin connector:
Yellow with a green stripe
Green
Yellow with blue stripes
Yellow with white stripes
Light blue
Black
I suspect this is a connection to the original alternator?
and outside this six-pin connector, a single yellow connector with a male pin. I suspect this is a connection to the rear brake light switch
Then there is this 3-Pin i cannot identify, the Diagrams are not clear about this:
In the front of the Wiring Harness is a 6 Pin, i suspect these are the Control Lights (Turn Signal, Oilpressure, Neutral, Light?)
Iam very thankful about every hint i can get on this.
Thank You!
| Color | Function |
| Brown | Switched Positive |
| Black | Ground |
| Red | Constant Positive |
| Yellow | Brake Light? |
| Blue with Red Stripe | Brake Light? |
| Green with white Stripe | ? |
| Orange | Capacitor/interrupter left right? |
| Green with red stripe | |
| White with red stripe | |
| Red with white stripes | |
| Blue with white stripes | Neutral |
| Gray | Capacitor/interrupter left right? |
| Pink | Horn |
| Dark Grey | Turn Signal |
| Dark Green | Turn Signal |
Green
Light blue
Black
Thank You!
