nikiforova
My spark plug caps not putting out 5k seems like it a problem
at 20k it starts at .4 and drops to 0 almost immediatelyHad to look back.....5000 Ohm caps. You can recheck on 20,000 Ohm scale. The 1 or 2 on 2K scale don't sound right.
So wait, the orange that is connected to the coil at all times, or the orange thats currently on the bike that gets plugged into the coil?That's good -up to you.
Just to re-clarify; what we're attempting to do is have everything hooked as normal - except Orange from coil - power-up, verify voltage to ground @ R/W at coil.......then "tap" orange wire to bare ground to simulate ignition - check sparking @ plug cap to grounded spark plug
Okay i got a spark this time around.Yes, orange connected to coil, not harness orange. (Sorry was bleeding brakes)
Okay. Ive been reading about the gonzo unit. Is that the direction i should plan on heading in?Well, crap; that's pointing to a bad TCI Unit. No spark would have implicated the coils/caps as guilty.
Order placed. Should be here at the end of the week. Hopefully that harness doesnt take too long. Ive been reading about the gonzo swap since that was mentioned on the first page. Ill keep y'all updated as it progressesSeems so.
