Welded Frame, Bike wont start.
nikiforova
Illinois
jpdevol
XS650 Junkie
XS650.com Supporter
26187
There was a sidestand safety switch on the '82-'83 models. It acted upon a relay which killed the ignition when activated. There were two "triggers" for the relay, the sidestand switch and the signal from the neutral light. One or the other had to be in effect or the relay would kill the ignition. If you just removed the sidestand switch, the bike would only run in neutral and die when put in gear. You must remove the sidestand switch AND the relay. No jumper wires are needed, just remove both items.
'78E Standard, '83 Heritage Special, and 3 Euro twins
We need to trace down that relay in addition to the sidestand switch
jpdevol
XS650 Junkie
XS650.com Supporter
26187
Should be ok. Connect everything, leave side stand switch and that relay unplugged, turn switches on see if it will spark or start.
nikiforova
Illinois
Still nothing :/
Now I’m noticing that my gonzo isn’t getting near 12 volts
jpdevol
XS650 Junkie
XS650.com Supporter
26187
Gary - On the Gonzo - it's my interpretation that the Wh/Gn is not used??:shrug:
Niki - Ok, you're gonna have to trace the Red/White (not Wh/Red) backwards from Gonzo checking for voltage to ground until you find where it's gettin lost.
Also, probably should tape that bare Wh/Gn from harness to insulate
Jim
XS650.com Supporter
Kansas City Mo.
Just so y'all know, I'm out of town and don't have access to all the tech shit on my computer.
I kinda feel bad that I sold Niki this wire harness and now I can't help make it work...
nikiforova
Illinois
Seems like im losing a lot of voltage from the bike harness to the gonzo unit. Im not really sure what to do at this point. I kinda wanna hit my head against a wall.
jpdevol
XS650 Junkie
XS650.com Supporter
26187
No problem Jim: with your connectivity, if ya see me make a mistake, maybe give me a thumbs down or a sad face ??
Niki - if ya can, we need to know about where the voltage gets lost
gggGary
Behind the ears too?
XS650.com Supporter
Baraboo, WI, USA
Two common voltage loss spots are ignition and kill switch contacts.
Could always jumper a hot to the Gonzo. don't leave it sitting with voltage and motor not running.
Jim
XS650.com Supporter
Kansas City Mo.
Iirc, Jack Left one hot overnight just to see what happens. Didn't hurt it.
jpdevol
XS650 Junkie
XS650.com Supporter
26187
Here's a better diagram. Red/White wire at "ignitor Unit" (second from right) trace that back - each black dot along the way is a connection- go all the way through handlebar/kill switch to fuse block. And....what Gary said
nikiforova
Illinois
Dont feel bad! I seriously appreciate all the help that youve given me. Ive just got to work and Ill be here until 4.
Im having a hard time following this diagram and the instructions accompanying it. Does the brown wire from the main switch turn into the r/w that I should then follow from the fuse to the handlebar switch? Im having trouble following the r/w from the ignitor to the main switch and fuse.
