Yeah I definitely blew an ignition fuse or two yesterday. Got ‘em replaced this morning and it was getting 12 volts then all the sudden it’s reading 8-8.5. Ive been thinking about switching to inline fuses to get away from this bulky fuse box. Would yall recommend that? Also, is there a chance the gonzo is fried because of how I had it wired?If you had to repin the connector, you might recheck the fuses. Might have blown one.
Im working on tracing it back now. Im about up to the coil. I dont think ive come across any connections so far? maybe ive missed them in this heap of wires. It sorta hurts my brain to look at.Are you more comfortable tracing R/W circuit back or do you want to try hot jumper to power Gonzo?
Got any friends with electrical knowledge? in-person
Cool Im going to get another Gonzo ordered asap. I have another stock fuse box coming in the mail tomorrow or monday. Mine is honestly shot tbh, the main fuse holder is loose and the headlight fuse holder is non existent. hopefully that will help in terms of holding voltage. I appreciate you not overwhelming me. Do you know whereabouts the wire from the fuse to the main switch changes from r/w to br?The gonzo could be damaged. I'd get another ordered - good to have a spare anyway.
The only issue with the fuse box is the clips can get weak if been hot and glass fuses. Current available boxes with blade fuses are larger. Inline is an option if issues develop. All will blow if wires not right
The kill switch and fuse box are points of interest to see where voltage is going. I can go quicker - didn't want to overwhelm ya
I can walk through hot jumper if needed.
All your call
Yeah im not sure how much he'll charge if he has one. He said that if he has some that they'd be from the late models because those are what he parted out. Im going to be dropping off my old tci tomorrow and hes going to check if hes got the exact one or a 6 pin.Also, the only TCI igniters - that I know of that will work - is what you have and $800 for new original or 82-83 used if can find - probably 80-81, but connector different (6 pin)
This is actually exactly what ive been doing! Its like that mount hole was made for tracing power. Cant think of anything else it would do!!Should've said before - Tip: to trace power, I like to ground black probe in gas tank back mount hole (mid-bike) and jam something to hold it there, then you can poke connectors with red probe around the bike to verify voltage.
Not sure.Jim - Did we get the pigtail to harness wired correctly ( I wasn't 100%) ?
My post #82 & #94 (for my future info)Not sure.
Sorry for asking for clarification so many times, I am still a bit confused..Solid red goes from 20A fuse in box to Ign. Switch, comes out as brown, then back to fuse box where it splits into circuits R/Y, Br, R/w
I understand what youre getting at. Im down to give a shot at running a second battery wired to the TCI/Gonzo and trying for spark. Is there a way to further isolate the reg if that may be the problem? Im interested in that as well.Still not had time to read through this
But I hear talk of buying a third Ignition Box .. that sounds wrong to me
You don't keep on replacing a light bulb at home 3 times if the lights don't come on.
Electronics can fry the regulators do if connected wrongly. So it can happen.
And as a ground rule ..the cheapest simplest first .. you save money and often find the fault quicker
Apologize if I have missed something here .But I am still at pulling separate wires ground and power
Thus eliminating other causes .And then after that consider new Hardware.
Might be there at the end that a new box is needed ,but after other checks
I don't know the Gonzo but Mr Jim does.
If the 12 V and ground is not there . I cant see any point in buying a third Box in fact the Stock one can still be OK
Since that is what is called a Control experiment methodically.
Box 1 did not spark
Box 2 did not spark either
--> Then there is a clear Possibility the first Box can be good
I Would provably insert the stock Box 1 and again ..try to ensure that 12 V and Ground is there at the relevant pins
And start looking for a Spark
One advantage with the stock setup is that there exists ..fault finding instructions and service manuals online
fex there
https://thexscafedotcom.wordpress.com/2011/01/10/xs650-manuals/
Again apologize if I am off I have not read it and wont get time as i Looks now ..
If i unplug it and try to turn the bike over could this cause a spike in voltage and hurt my electronics? Im at the point where I have 4 things I want to try.You can just unplug the voltage regulator. "for testing purposes"
Okay this is where I’m at this morning: the gonzo is not getting enough power, however, there is no power being lost from the ignition fuse to the tci harness on my bike. Once I plug into the gonzo harness I experience a 2 volt drop.No problem, with the regulator unplugged there is NO charging.
I like this. Ill have to give it a go. My current readings are pretty not greatVoltmeters, VOMs have their place, but I do more of my testing with a turnsignal bulb with alligator clips.
the bulb doesn't light, there's a break somewhere,
the bulb lights but is dim, there's a bad connection frayed wire etc. in the circuit
the bulb lights BRIGHTLY I have a good SOLID 12 volts and I need to look elsewhere.
The white wire taped to the bulb is just a hook to hang it somewhere convenient.
This rig has found and fixed more problems than 90% of the voltmeters in the world. ;^)
