MSD 8991 Self-Powered Timing Light ("Self"?!...means battery). A retrospective.
Probably bought this ~15 years ago when I was installing an MSD "Ready-to-Run" distributor in my '73 Z/28 rebuild. Was a replacement for a '70's vintage light that had run its race. Thinking back, not sure why I bought the "Self-Powered" version, guess I must've liked the idea of only a one wire connection - the inductive pickup. It worked well when new-ish. Editorial note - astonished by the $280 price on this thing today!
Fast forward to today. Haven't used it for some time but got it out to do a timing check on the XS (and eventually KZ, etc.). Didn't work. Hmmm. So open it up and am confronted with (forgot to snap a pic of the initial "look") pos carnage of leaking batteries, corrosion, et al. WTF? Fortunately, the battery box, etc. is somewhat standalone and just connected via wiring to the balance of the guts of this thing, thereby not trashing everything with the battery f/u.
My guess is that the electronics in this thing - even without the trigger being depressed - have a constant slight current draw with the batteries in-circuit. There can be no other explanation for the total discharge. Interestingly, while my original little owner's manual blurb said nothing of the sort, the latest instrucciones on MSD's website say things like "The function switches can be easily (and inadvertently) depressed, so when storing the timing light, make sure the area around the switches is clear. Otherwise, the batteries will be dead on the next use"
AND "When changing the batteries, if you see corrosion, you will need to clean and scrape the terminals before installing the new batteries. If the corrosion is too severe, the timing light will have to be sent in for service". Again my guess is that they now cite these things to address the reality that it happens regularly, but for some reason don't want to fix it i.e. provide an easy means of taking the batteries out of circuit.
Here is a pic of the semi-rehabbed battery assy.
My first inclination was to just keep one battery out of the box when not in use so that the circuit was broken. But then I thought that sucks and I really don't want to take it apart twice each and every time I use it. So I got one of these little guys...
https://www.amazon.com/Button-Switc...9a-aa87-a908b5446dee&pd_rd_i=B076RLL1KM&psc=1
...and installed it as such so that it is a positive on-off switch, taking the batteries out of circuit when not in use. The only downside to this switch is that it has no indication of on-off
Should be a permanent fix... we'll see.
