Try flipping over the plug wire clamp, they can be polarity sensitive.
I swear I've never owned one that didn't need a bit of fiddling to light up....
Thanks for that! I didn't "know" to try that or set out to do it on purpose, but just by chance did try it both ways, as I clamped it on-off a number of times as I was fiddling.Try flipping over the plug wire clamp, they can be polarity sensitive.
Badly worn ways is a deal killer. About everything else can be fixed or replaced. Parts are still relatively easy to come by.Any pitfalls or things to look out for?
As @Jim says, worn ways, but seems unlikely as it is a hobbyist lathe. To me, the biggest shortcoming will be no gearbox, relies on change gears to change speeds. I personally would find that cumbersome in short order. I find my Logan 820 frequently too small / too light duty for some of the stuff that I attempt to do.Is an Atlas 6i8 a good small lathe? Any pitfalls or things to look out for?
Let me add some clarifications and additional considerations to this, cuz I don't want to rain on this parade, in fact I'd rather encourage it:As @Jim says, worn ways, but seems unlikely as it is a hobbyist lathe. To me, the biggest shortcoming will be no gearbox, relies on change gears to change speeds. I personally would find that cumbersome in short order. I find my Logan 820 frequently too small / too light duty for some of the stuff that I attempt to do.
To measure wear is it done with a good straight edge and feeler feeler gauges? Do you know what the wear limit is? ThxBadly worn ways is a deal killer. About everything else can be fixed or replaced. Parts are still relatively easy to come by.
It has a 3 and 4 jaw chuck and a milling attachment. Comes with a bunch of gears for speed and thread cutting changes. It looks like there’s several belt position changes that can be made to change chuck speed. No QCTP.Let me add some clarifications and additional considerations to this, cuz I don't want to rain on this parade, in fact I'd rather encourage it:
My Logan 820 was a derelict when I got it. IIRC, I paid $500 for the lathe, a turret tail-stock and a mechanical hacksaw. I did a full restoration on the lathe, then added the QCTP, two sets of tool holders, a new chuck, a face plate, drill chucks, a limited set of collets and made indexing attachments and a collet drawbar. All that said, it was a wonderful addintion to the shop and I use it constantly. In fact, I can not imagine living without it.
- if the scale of the machine suits your intended uses, then perfect
- if the machine has been retrofitted with a quick-change tool post (QCTP), then significantly more desirable
- if there is a bunch of tool-holders that come with the QCTP, then better
- if there are other accesories that come as part of the deal, then bonus points. I'm thinking four-jaw chuck, faceplate, tool-post grinder, indexing attachments, steady-rest, drill chuck(s), collets, etc
- if the whole thing is a screaming deal for whatever reason, then major points in favour of a buy
TheTo measure wear is it done with a good straight edge and feeler feeler gauges? Do you know what the wear limit is? Thx
check is to move the carriage say, 18" away the chuck, lightly snug the carriage stop bolt til the carriage will still move with a little bit of effort, now wind the carriage towards the chuck. See how much further you need to turn in the stop bolt to feel the carriage movement start to drag again. The more you have to turn in the bolt the worse the wear. I inherited my dad's old 9" south bend
Points for the four-jawIt has a 3 and 4 jaw chuck and a milling attachment. Comes with a bunch of gears for speed and thread cutting changes. It looks like there’s several belt position changes that can be made to change chuck speed. No QCTP.
Asking $1200Points for the four-jaw
Major points for the milling attachment
QCTP's are readily available for not much money
Change gears needs to be a complete set
Face plates, collets and other accessories can be acquired as needed
Bottom line is how much, assuming ways are good?
IMHO, that's on the high end, unless the machine is in really pristine condition. Let me see what I see as comparables locally, just out of curiosity.Asking $1200
Ok, based on what I'm seeing locally, the asking price is not unreasonable, again, very much a function of condition. For me personally, the milling attachment itself may be worth up to 15% of the total asking. Have any pics to show us?IMHO, that's on the high end, unless the machine is in really pristine condition. Let me see what I see as comparables locally, just out of curiosity.
Never mind, I found the listing. Hope you don't find that intrusive. It looks to be in very nice original condition and seems to be the best current offering in that size range. If you're interested, better get after that right quick. I suspect that it will sell quickly!Ok, based on what I'm seeing locally, the asking price is not unreasonable, again, very much a function of condition. For me personally, the milling attachment itself may be worth up to 15% of the total asking. Have any pics to show us?
The seller is a friend of mine and keeps everything in very nice shape. I’m going to see it today.Never mind, I found the listing. Hope you don't find that intrusive. It looks to be in very nice original condition and seems to be the best current offering in that size range. If you're interested, better get after that right quick. I suspect that it will sell quickly!
WOW, as a point of comparison, I found a Logan 820 (like mine) in Ottawa, no tooling, accesories or anything else except a a four-jaw chuck and it sits on an original Logan base cabinet. Listed at $2300!
Makes your Atlas find look better and better...
