At least there’s a hole to pass food and water to the detainee.She lets you out when you sober up?
Back to this old thing. I want to store it inder my deck outside and to do that I need to lower it as much as possible. In the first pic you can see the po has the saw mounted to two 2x4’s with small casters underneath. To lower it I bought some 3” channel and welded 4x4 angle on the ends to allow the use of 3” swivel casters with brakes. The vertical leg of the 4x4 and]gle was trimmed to 3-1/2”. Once assembled, the channel should ride 1/2” above the ground. I haven't measured yet but I think I’ve reduced the height by at least 3-1/2”?Here’s a cool old tool I just picked up. A power hack saw. Literally cost me $1.00. I took it apart for transportation and did a quick clean up. I fixed the power cord and added an on/off switch. Still needs some adjustments a couple of new belts but it cuts! Quite heavy and it does take up a bit of space but I always wanted a saw so I’ll keep this for a bit. I need to find some spare blades. Takes 12” or 14” blades.
Check out the attached video of the saw in action! At the end of the cut, the blade pops up and disengages from the drive.
Not sure if the saw is supposed to cut on the push or pull stroke? Judging by the chip tray I guessed it’s on the push? But second guessing myself maybe is should be pulling the blade into the cut applying force to the fixed jaw of the vise?
View attachment 352518View attachment 352519View attachment 352520View attachment 352521View attachment 352522
That ceramic piece is an easily replaceable part, almost a consumable. A small TIG welder is super handy to have, and 20 dollars is a bargain!Finished a small welding job for a guy. He owed me for the rods on top of the work. He didn't have the $20 for the rods. Had bought this second hand 130 amp portable Tig welder then decided he didn't or couldn't weld with it.
Said no, then an hour later I thought why not. Now, ( still to pick it up), I now own a small tig. The ceramic covering around the tip has a chip so ????
130A is OK on a MIGGotta learn to weld with it now. And set it up proper and learn about differences in wires and such.
Any tips or links to a utube vid??
I did say tig.....it's a mig
This looks like a good wedding tutorial
https://www.weldclass.com.au/blog/87-mig-welding-for-beginners-video-with-shauno-from-4wd-24-7
Thanks - I only showed you the good ones. LolThose welds look fine to me... aren't you glad to have added to your skillset?
The only thing she has ever dug up was a rabbit nest. She found it and dug it, my old husky did the eating. He even swallowed one whole when I tried to take it.Dog's thinking "If I did something like that I'd get my ass kicked".
Carts are 25 cents at Aldi's!I’ve been looking for one of these for a while. We used to use them in our shop at my last place of work to move parts and tools around. Invaluable. It’s part of a plan to declutter the garage. I can put lots of stuff from the floor, inside the cart and it’s no longer in the way. $30 well spent. The small, double carts are harder to find.
I’d like to get one more.
View attachment 354838View attachment 354839
I know but that would be considered theft and I’m too honest (orBetcha your local grocery store has a mess of them lying around...just sayin'!
Curious to see how it does.Saw this on YouTube so it must work. lol. Total investment under $15 so worth a try. Will report later if it helped.
Rechargeable, different light modes, can wave it on and off (optional).
View attachment 354840View attachment 354841View attachment 354842View attachment 354843
The dastards are charging €2 each for them around here.Carts are 25 cents at Aldi's!
I took ten...
