It's time to hoard them if we can find them.Same as everyone else, Boyer is having trouble sourcing plug caps.
I bought a bunch of those zero ohm NGK caps for cheap. I got them from Racing Planet USA Inc. It took time for them to show up, so I think they may have come from Germany or ??.You can only get red caps on the east side of the pond.
I managed to score a spare set last year, but every time I've looked since, no luck.It's time to hoard them if we can find them.
That's ok if you can only get the 0 K, use a resistor plug. The ignitor doesn't care where, as long as it's there.The ones for a Boyer are 5K.
Does it use the mechanical advance unit?Today I just advanced the timing on my PAMCO. Now the TDC line on the rotor properly hits the F-mark.
However I noticed when I rev to 3000k rpm, it doesn't advance.
It only advances around 4500rpm. Don't really know how to proceed.
Yes, I believe so (photo attached)Does it use the mechanical advance unit?
I believe he’s going to tell you to lube that shaft.Yes, I believe so (photo attached)
Im on it coach! Enjoy the music!I believe he’s going to tell you to lube that shaft.
And while you're in there, lubricate the bob weight pivots and the slot where the bob weights rotate the shaft as they're thrown out. Make sure everything moves nicely with no stickiness. That should fix itIm on it coach! Enjoy the music!
Love the imagery!Carbs worked loose on my morning gravel road ride, had a huge backfire on the decel,
Roadside fix and back on the ride, came home, made sure they were TIGHT, just came back from my evening ride ( it’s summer, I try and “bookend “ most sunny days with an early morning and late evening sunset ride.
Parked up in the old shop at home, played with a camera filter at last light![]()
Is that a 74-76 Vee Dub bus bumper on the bench?Carbs worked loose on my morning gravel road ride, had a huge backfire on the decel,
Found a “donor” gear shift lever from a friend. I believe it was from a Virago. Straightened it near the splined section using my induction heater - great tool. Cut it to length the drilled and tapped the piece. I test fitted it and it appears to work well. Polished it up a bit, now it’s ready for a bit of paint.Well, more excitement. I was on the way to have a coffee with friends this evening and while downshifting, the linkage for the gear shift broke. Fortunately it broke close to home so I was able to ride it home in first gear, hugging the side of the road. Now I need to replace the short gearshift arm. I’m planning to make it from steel vs aluminum.
Anyone know if the spline on the lever is unique to the XS or is it common among other Japanese (or other) bikes?
View attachment 331339View attachment 331340View attachment 331341
