Shovel Jockey
Piano Tuna
- Messages
- 238
- Reaction score
- 142
- Points
- 43
evidently the press in brass nipple opposite the one you see for the choke crossover tube blew out one day during a carb backfire. Having to fabricate one.
starship!Broke my bike down for refinishing a few weeks back. Spent this week blending the welds on the exhaust I made....long process. Also made this trick little piece of functional art to hold some spare plugs in the stock coil location.
I'm far from a pretty welder so I'd never make fun of anyone else's. I bought a TIG years ago and have never had time to teach myself so my MIG welds have had to do. The exhaust I wanted to look like 1 seamless pipe though. I'll try to grab a pic of them laterView attachment 338700 Nice work, you should see the welds on my chopper, or not. I should have posted pictures of em on the Halloween thread
Paul, that is cool as fek!Added the last little 3 inch piece to one of my pipes today for the fishtail to slip onto and blended it in. Just waiting for a scotch brite conditioning belt to make 1 more pass over the pipes with before chrome. 1.5 all the way back then up to 1.75 to slip into the dual fishtails. Just debating some type of 2 piece finned collar because the flat ones don't do it for me. There are bungs welded to the backs of the pipes for mounting plus the transition between sizes so I can't remove them now.
Sweet pipes dude! You're gonna gonna have to be careful going under some bridges. Seriously though, I like em, those are cool! Trying to look at the mid control/brake pivot and see how you did that. That's one of the conundrums that I have run into and put to the back of the list to deal with later (eh...14 years or so give or take) The guy who fabbed mine pulled a fast one on me. He had the controls , brake pivot and exhaust all set up and it looked like it all fit but he had the headers on loose so the foot pegs would fit using the exhaust mounts. Also the brake was in the path of the pipe, I couldn't come up with a solution other than lower or raise the pipes somehow?Added the last little 3 inch piece to one of my pipes today for the fishtail to slip onto and blended it in. Just waiting for a scotch brite conditioning belt to make 1 more pass over the pipes with before chrome. 1.5 all the way back then up to 1.75 to slip into the dual fishtails. Just debating some type of 2 piece finned collar because the flat ones don't do it for me. There are bungs welded to the backs of the pipes for mounting plus the transition between sizes so I can't remove them now.
Oh any advice on getting the horribly mangled screws out of the back end of the carb? The mounting bracket that holds the carbs together goes there, but so far nothing I’ve tried has released those soft screwsView attachment 338888View attachment 338889
still cleaning up the carbs, o-rings and new needles are on their way. Still have to pull the main needle jet and give that a good cleaning too, but I should have the carbs put back together this week!
+1 on that. I'll add that heat is your friend. Zamak (zinc) expands faster than steel.Penetrating oil…give it time to work. Maybe even a day. Punch the centers then drill them carefully and then use a reverse drill bit to back them out. Good luck…maybe file the tops flat to give yourself the best shot at drilling the center
