You're more than welcome. If I remember to tomorrow morning I'll take pictures of the spare filter I have.thank you for clarifying
@zrx1100 Here we are, the scriber is pointing to the filter relief valve. If anyone's interested, the filter part numbers from Honda are shown in the other picture. I've just ordered half a dozen spare filters, Hi Filtro HF-112, readily available and cheap.You're more than welcome. If I remember to tomorrow morning I'll take pictures of the spare filter I have.
And check valve to piston clearance too, I think.I think I should do some CR calculations, could be a bit high for road use.
Approx 12.8-1. Oooops! Too much me thinks. Pistons to the mill for a haircut.I think I should do some CR calculations, could be a bit high for road use.
I’ve been running that set up as long as I’ve had my bike. I much prefer the paper filter over the screen. I bought a handful from Amazon. Quite inexpensive. I think the Hi Filtro brand is decent. Mine are no name Chinese stuff.@zrx1100 Here we are, the scriber is pointing to the filter relief valve. If anyone's interested, the filter part numbers from Honda are shown in the other picture. I've just ordered half a dozen spare filters, Hi Filtro HF-112, readily available and cheap.
I agree, the HF filters are decent enough for the price, readily available too. I have used them on various bikes for some time. The HF-112 is available in the UK around £2.50 or so. Very cheap.I’ve been running that set up as long as I’ve had my bike. I much prefer the paper filter over the screen. I bought a handful from Amazon. Quite inexpensive. I think the Hi Filtro brand is decent. Mine are no name Chinese stuff.
We used to call that claying the cylinder. Putting clay on top of the piston and turning the engine over to see how much clearance you actually have.And check valve to piston clearance too, I think.
Be sure to throw talcum powder on the piston and dome first so the clay doesn't stick.We used to call that claying the cylinder. Putting clay on top of the piston and turning the engine over to see how much clearance you actually have.
What exactly are you trying to sort on these carbs?Removed the carbs (yet again). BS34's
They are spotlessly clean inside; and seemingly no blockages.
I split both units apart to check the fuel supply 'T' tube between them and no blockage there either.
Blasted carb cleaner through all orifices and compressed air to follow. I'm re-reading a few posts here and the carb guide again.
I will buy some upsized Mikuni brass as I'm running a through exhaust with minimal baffle, along with Unipod filters.
Float heights checked and good.
Any suggestions as to what jet sizes I should try?
Currently: 132.5 mains / 42.5 pilots.
Did the slides show any sign at all of stickiness? I think that was a suggested as a possible issue. Did the slides/diaphragms pass a drop test? New throttle shaft seals fitted?Removed the carbs (yet again). BS34's
Long story Bazz all documented on my build thread. Basically a misfire we believe caused by a fuel starvation issue.What exactly are you trying to sort on these carbs?
Hi IBALT will do on Sunday. I'm at home now researching Carb stuff whilst waiting for Welsh Water Board to come and sort my supply out!@Adamc Sorry if this is an imposition, kindly humour me. Would you measure battery voltage and ignition coil +ve terminal voltage please?
