Gary you are the king of dislodging stuck/stripped jets!!!was handed a float bowl with a stuck pilot jet the slot already gone.
drilled into the jet "aways", tapped in a T15 bit and out it came.
Nice job...Whipped up some seat hinge pins out of stainless because I lost one and couldn't source new ones anywhere.
View attachment 353963View attachment 353964View attachment 353965View attachment 353966
On the edge of my seat....the 71 "Great Bear", all the head threads came out with one of the exhaust valve cover studs.
Three hours later....
Mikes valve covers and o-rings? replaced with fat silicone o-rings don't need to over tighten those.
all buttoned up now. Valves were fine, cam chain very loose.
Got 135 both sides, getting closer to firing it up.
Ordered from Partzilla.Hah! I used 16p nails, and some creatively twisted coat hangar wire to make a loop for the cotter pin to catch.Nice job...
Hinge pins and their little cotter pins sort of drive me crazy, so last year I made a quick release skewer, an idea that's buried in one of my build threads:
Cool Nash!So. All I wanted to do was get some repop rear turn signals, I wanted fresh and shiny and don't need NOS for this application. Anyway, all the red lens versions are/were sold out. No prob, I've got at least 4 red lenses on hand, so I get the repops with orange lenses intending to simply swap the lenses. Oh no. The screws will not come out. Snapped the first one, so I took my time with the second, working it back and forth slowly, getting a little further each time, til it snapped. So now if I want to save these repops, I gotta get the remains of the screw out, or at least turn it into a hole for a new screw. Ended up cutting off a bit of the boss with a Dremel wheel to create a flat surface to drill into. Took a few hours, but I was able to create new holes and run fresh screws in. (All the time taking great pains not to scratch up my shiny new bits!) Great! But wait, there's more! I wanted to re-use my mounting studs, the hollow all-thread, as the new ones would need to be cut, too long. But- the bullet connector on the repop lights won't fit through the original stud. So, having brand new set of bits handy, I reamed out the studs rather than replace the bullet. "Sometimes I just feel like doin' stuff like that!" Anyway, all's well that ends well. I got shiny new red signals. Just took too long! Next up-install my new stainless cam shaft plugs.
