I have one of those rectifiers. They take 8mm female terminals. A bit bigger than I was used to, usually 6mm.
Are you still running the original alternator or a PMA type?I fitted a cheap voltage meter to the handlebars a couple of weeks ago and noticed that it started at 13.5v but would sink below 12.5v, especially after a 30 minute ride. It was only cable tied as a temporary mounting point, I may look into a more permanent location and thinking about replacing it with a dial one that is more in keeping with the looks of the round clocks. If you look carefully you will see that they misspelt Voltmeter, it says VolFmeter which really doesn't fill me with confidence LOL. I used the feed and earth from a coil so that I'd know what voltage the coils were getting.
Today I modernised the charging system with a new rectifier & regulator.
My run of bad luck with ebay sellers continues, after a lot of searching I saw an adjustable regulator and ordered it, only when it arrived it was a none adjustable type that was available (same price) from a dozen other sellers. When I contacted them they said that the adjustable one was no longer available and offered to refund if I sent it back. Didn't see the point sending it back as I would have bought the non-adjustable one if I hadn't seen this one anyway. I see today they have changed the advert to the non-adjustable one, so no point in me giving a link.
The rectifier took a while longer to be delivered and finally arrived yesterday. I needed to grind down the male connectors to fit the female spade connectors and I used some heat sink compound when mounting it to a plate of aluminium (cut from a scrap piece). I used 14 AWG cable which is probably overkill, the original cables look to be about 18/20 AWG.
Now getting 13.5v at tickover and 14.3v at anything above 2,000rpm so they are doing a good job so far. The regulator just fits in its current location with about 1-2mm gap in the bottom corner from the side cover.
View attachment 354303View attachment 354304
I use a meter very similar to this on my commandoNice work on that reg/rec, very tidy! I purchased that same Volf Meter lol, and I didn’t like how slow it was to refresh the readings, and how it said volf… I bought this analog gauge that looks pretty similar to the stock gauges, only thing about it is the needle is very jumpy, but has been holding up for a cheap gauge. Made this bracket for it, I’d like to try and relocate it where the center “console” indicator box is and fabricate a new little cluster there with that gauge and indicators together.
View attachment 354305View attachment 354306View attachment 354307
Nice neat installI fitted a cheap voltage meter to the handlebars a couple of weeks ago and noticed that it started at 13.5v but would sink below 12.5v, especially after a 30 minute ride. It was only cable tied as a temporary mounting point, I may look into a more permanent location and thinking about replacing it with a dial one that is more in keeping with the looks of the round clocks. If you look carefully you will see that they misspelt Voltmeter, it says VolFmeter which really doesn't fill me with confidence LOL. I used the feed and earth from a coil so that I'd know what voltage the coils were getting.
I'm still using the original alternator so I used a type B reg.Are you still running the original alternator or a PMA type?
Clean! I like that ignition switch mount, what’s going on there? Is all that mounted to the stock gauge cluster bracket?
My forks are the later variant. I put 15W Belray fork oil in the XS650SH because it’s all I could get. No good. It’s much better back to 10W. I believe 5W will offer piss poor dampening on the rebound. Speaking for myself, I wouldn’t try it as I feel I already know what the result will be. The only modification I’m running with is increased oil level in the fork. This decreases fork dive in hard braking.After replacing fork seals and oil this winter I’ve never been real happy with the front suspension performance, which to modern day standards, would be poor at best. The oil I removed from the forks was an unknown weight. I searched on line and decided to try 15W oil. The forks were quite stiff on compression and I thought the ride was a bit harsh. I had some time today so I did a quick oil swap to 10W. Well that made quite the difference and I’m almost tempted to try 5W oil. The suspension is stock 34mm with progressive springs.
Me and Dad putting that car together in 1983- we found the continental kit in an Idaho junkyard, and pulled it off with hand tools on a hundred degree day, praying for the bolts to just snap. She's logged some miles, MD to CA and back, as well as all over the midwest and New England. Good eye!Cool Nash!
OHV or L head?Me and Dad putting that car together in 1983- we found the continental kit in an Idaho junkyard, and pulled it off with hand tools on a hundred degree day, praying for the bolts to just snap. She's logged some miles, MD to CA and back, as well as all over the midwest and New England. Good eye!
On my present 650D I am running 5w fork oil. But I do have a history of preferring lighter rather than heavier oil in the forks. It's easy enough to give it a try. You can even blend equal amounts of 5 and 10w if you want to try 7.5w oil.After replacing fork seals and oil this winter I’ve never been real happy with the front suspension performance, which to modern day standards, would be poor at best. The oil I removed from the forks was an unknown weight. I searched on line and decided to try 15W oil. The forks were quite stiff on compression and I thought the ride was a bit harsh. I had some time today so I did a quick oil swap to 10W. Well that made quite the difference and I’m almost tempted to try 5W oil. The suspension is stock 34mm with progressive springs.
But how are the brakes?Today I got my X's on the road "legally" I'm very very pleased with it
It certainly runs better than I ever expected and the handling is superb for a rigid frame
It revs out with no flat spots and brakes well too
There's no smoke from it all and the motor just feels "strong" if you know what I mean
Brilliant fanxBut how are the brakes?
