I was thinking about my long lost XS650SH and remembered a thread from TwoManyXS1bs where he made a gear counter so he would always know what gear his bike was in. A year or so after that thread I noticed how the gears could be tracked mentally and I call it the Rule of 3. It goes as follows:
3rd Gear 3000rpm Approx. 30mph
4th Gear 3000rpm Approx. 40mph
5th Gear 3000rpm Approx. 50mph
Perhaps I should have called it the Rule of 3000? This has stuck in my head and I find it also applies to my Virago XV1000SE. So should I ever get a little lost amongst the gears I just simply glimpse the Tacho and I have my answer.
I was thinking about my long lost XS650SH and remembered a thread from TooManyXS1bs where he made a gear counter so he would always know what gear his bike was in. A year or so after that thread I noticed how the gears could be tracked mentally and I call it the Rule of 3. It goes as follows:
Funny this one, I had a Suzuki GT380 in the glorious 70s with onboard gear counter. The japs were always ahead on their tech. But then I wondered, if it ain’t pulling, change gear!
Happy Thanksgiving y’all!
Put some fresh rubber on the rear, by hand.. 😫 Always kicks my ass, I don’t think I have the right technique but got it done with minimal rim damage. The old was worn down so much that I noticed about a 100 rpm increase at highway speeds with the new taller rubber.
And decided to purchase a Heiden Tuning oil filter, I like the look. Oil change looked good with no funny business floating around.
Did a second head torque since top end rebuild, no oil leaks on the new gaskets, but my right cam seal is leaking and needs to be replaced.
Something I need to address is a persistent backfire out of the intake ever 30 seconds more or less while idling, its getting very annoying. Usually it just drops the idle and it returns, occasionally it will stall and pop my vacuum cap/hose off, but never happens when I’m on the throttle.
It started happening more after my recent road trip. New manifolds, no air leaks as I can tell. I just took the carbs off for a quick clean and bumped up the jets a step to see if it was a lean issue but still happening, ignition timing issue?
Other than that it’s been pretty reliable, it’s my only vehicle right now and hasn’t let me down.
Side stand modifications..... I have done a search for side stand mods and no results that will address my concerns about the side stand on my 76.
To start with ... I don't think the arm itself is the original but I don't think that the correct arm will get me the side stand I like.
In my opinion the mount is too far forward.
My thoughts.... the mount should be about 2 inches toward the rear would make it a lot more user friendly.
Well , not pleasant outside, so thought I would attack this.... found a Honda side stand in my parts... a little cutting and machining... will do final assembly and welding after tweaking and test fit
Carved up a turkey to get at the wishbone.
Going to bend, not break it.
Slather some of that white grease from cold gravy on the wishbone top. Naturally high in zddp! All my starting issues will be behind me. Happy Thanksgiving all!
1157 ... 2 element bulbs up front... bike is a Canadian version .... so came with the extra circuit , but they were only on with headlamp switch on... I just tapped into always on tail light .
Have had a hankering to build a custom bitsa...pulled a bare frame from the shed and have de-tabbed it, shortened the rear hoop, cleaned up nasty factory welds and so forth. For those who abhor any application of the the grinder to an XS frame, I understand, but this particular frame was never going to be restored. Build direction still in the embryonic stage, but the intention is a very clean and simple look. Mock-up pics to follow.
The key difference between the "de-tabbing" i see on FB m/place and what you have described is, you qualify your actions when you talk about the factory welds. A welder talks like that, the mall ninja's from the cafe racer forum talk about accessories and how sick something will look once they mock it up before losing interest in a project that gets worse before it gets better. I know, because i think lile that.
It sounds like you have started a nice project and i am interested to see how it goes, and keen to offer encouragement as you need it mate!
There is no sin in custom motorcycle making, do your best!
A bike maintenance weekend it seems to have been.
On friday night i entered into another chapter of maintenance on the 2006 Suzuki VL800, with leaking coolant and missing headlight screws alerting me to their state on a ride to the Bendigo Historic Motorcycle club meeting a couple of Sundays ago.
Another adventure worth writing about. While the weather was terrible, and has been on and off rain since July, with fierce winds, hail, and thunderstorms pervading week in and out. Leaving my fellow Victorians wondering if spring will ever break with winter this year? The roads are terrible and the state government has recently announced that they will be focusing only on built up areas and the metro networks. It was these combined conditions that had me belting along the corrugated and pot holed roads of Jaara country, trying to maintain a decent clip when all of a sudden at 100km/h the headlight popped out.
I pulled over carefully bringing the VL800 to a steady stop and popped it back in again (wondering how in the f#ck did that road rattle those loose? swearing i had Loctite'd the buggers in). Taking the ride extra carefully i passed through a hamlet on the way to Dunnolly where i could tape the headlight back on again, once i had sculled a ginger beer.
That was when i noticed coolant leaking onto the front guard. Once i had checked the coolant leak. But rode home no issues. I figured i must have a holey radiator and proceeded to research prices on new, or good radiators, and picked up some JB weld, later in the week. I topped up the radiator only to get a better look from where the leak originated and figured it was in the top part of the radiator, if it wasn't just the hose.
So Friday night for as long as i could after all of my family commitments i played around, draining coolant, in the rain, whilst leak testing the radiator. I felt like crap (something i had eaten) and went to bed early, and rose basically at dawn, to a slow start to the day, but managed to get the new overflow bottle installed, the headlight reinstalled with spring washers and Loctite, and the coolant bled through and bike running.
I couldn't get the thermo fan to come on, and the sensor reads 50Mohm. That's a future fix, and I will face that at some point in the next few weeks. All in all good news on the Saturday morning, my hack is back on the road.
Spent all of my free Sunday alone time away from the family practising Zen meditations (and somehow, not altogether failing nor succeeding) in motorcycle restoration.
The rear and front wheels both needed some love, care and attention, and while just a new tyre, on each and some disk machining was probably all that was required, the disassembled and rat flavoured project needs some deep kind of love. I figured, a wheel bearing kit will be a simple process and will save me having to do it later on, and perhaps eliminate one more goblin 👺 from popping up in a more inconvenient manner.
The wheels are loose anyway, so all i had to do was pop the seals out (nice and crispy after perhaps 30 years of neglect) with the tyre iron. Making sure i cleaned the beads near the seal point with a fine point, cleaned with solvents and heated everything up with the heat gun.
I love heat guns, torches, thermocycling, and press fit parts.
The flat faced drift was used to drive the bearings out with some force. No damage to the mating surfaces, but the old bearings got a solid mashing.
I prepped the surfaces and gave all of the spacers, Speedo gear, axle bushes and so on a really good clean. I had to spend some time sanding with emery and medium steel wool to get the fitments to a smoother and less corroded state than what was found.
Froze the bearings and seals and drove them all in with whatever bearing drivers i could improvise. The seals slid in by hand and everything got a thin film of moly grease (i normally use natural but it's in the other workshop) and i felt whole and complete, and stunk of kerosene, grease and various aerosol lubricants.
That feeling subsided rather quickly once i realised the mountain keeps jutting up, and the next day's climb requires that same amount of effort to round the col of the swing arm pivot kit, and the steering head bearings.
Until the next chapter, know that working on your projects can really help distract from the problems of your existence. But it goes on forever.
Thanks for the encouraging thoughts...won't be much accessorizing, but more minimizing what's needed to make a bike functional. So far, the tail hoop is shortened, all of the side cover tabs, passenger peg mounts and whatnot deleted, center stand and exhaust mounts deleted and all visible welds dressed. I'll hold off posting photos until I can see this thing getting some legs, so to speak.
Removed rear tire and swing arm... removed, checked and lubricated axle bearings and swing arm bushings... rear brakes.
Everything was in pretty good shape .... found a couple things in the process.
Missing clip for master link
One broken spoke
I can see why a 18 tooth sprocket may not work
All in all not bad .... 50 th birthday in February... for the bike that is
