I gave it some sibling rivalry when I brought home another one Tuesday nightView attachment 368654View attachment 368655
Today I started a front to back assessment/inspection, some bad, but mostly good, I made it about half way.
The bad View attachment 368656View attachment 368657View attachment 368658View attachment 368659View attachment 368660View attachment 368661View attachment 368663
The good View attachment 368664View attachment 368665View attachment 368666View attachment 368667
I personally have never seen a stator that clean before, or a tank, None of the wiring has been mutilated and appears mostly original stock. I included the tires because I thought they were splitting on the sidewall last night but it was just a factory moulding. I still don't know how old they are but they look cool, I had yo replace a broken clutch lever and left turn signal because the PO's kid had knocked it over backing out of the driveway. Once that was done I could shift through all the gears. It was hard to roll around and I thought it was because i could only get the clutch to partially engage as it was broken. I was wrong. As it turned out the more I used the front brake the more it started to freeze completely, thankfully that didn't happen halfway down the ramp because I didn't wait for help when I unloaded it. The other project front brake works good and has a Nissin upgraded MC so I could just use that set up or I could roll like the chopper guys do. Who needs a front brake anyway right? It's only like what, 75% or so of your stopping power?
On second thought, I rarely trail brake so I think I will order some stuff from 650 Central just not sure how much to bite off at this point in time. Forks aren't leaking but are pretty spongy so they need some work and might as well do bearings too.
Most definitely and thanks for the words of caution. What I have learned about tires alone in the last couple of years definitely gives me pause when considering riding on used tires. My triumphs tires had plenty of tread left but were almost old enough to vote by the time I had them replaced last year. The Sportster's looked like thisWow - that's better than just a survivor. Not quite 'time machine' but what a find!
The tyres mebbe look cool but you know you need to swap them out unless you enjoy hospital food?
and the wheel bearings sounded like an old click dial on a black and white TV. I did 3 sets myself last summer after what I had to pay to have someone replace the Triumph's. Thank God for Shinkos, 3 sets cost less than 1 of Pilots. Those dual sport/scrambler tires look cool and I can use them on my wanna-be flat track but they would probably ride like sh!t on roads around here as they groove alot of them and as I understand those front tiyres are known for wobbling on grooved surfaces.So for 3 days, 8-12 hours per day I got everything moved over and cleaned and timing corrected. I also decided to install new tires. I also cleaned up a few things that had bothered me for the last 13 years. So now the bike starts on the first or second kick (the Vape system was very easy to set up and works great) and I can stay out of the hospital from a broken ankle.
Just cleaned up a few things? Gave it a quick tidy, spit shine? Well you don't mess around, nice job. So how bad were the downtubes damaged? I am assuming the highway bars were those ones that clamp on with U-bolts and I only ask because I was about to mount some old ones I had from a basket case I bought years ago. I was going to try to use them as a jack point to lift the front tire off the ground as anything aft of that raises the rear tire and now I'm thinking that's probably not a very good ideah. So do you have any pics of the tubes?Well where do I start. About 13 years ago a picked up two disassembled XS2 650 bikes. One of the frames was missing some tabs which hold the battery box and the catch for the seat and the from downmtubes with slightly compresses from an overly tightened highway bart they had mounted.. Both engines had issues. With the wisdom of 60 some years (so I thought) I used the best engine and the best frame which resulted in a mismatched Frame engine combination. I sold a lot of the parts but kept the cases and the other frame. As years passed I came to realize the bike would be worth more if it had a matched frame and engine. So this was the year to correct the frame issues and move all of the parts to the correct frame. I would also correct a small timing issue from the original build. Both cranks were damaged on the original engines. I wanted to keep the characteristics of the 256 engine so I used a 447 crank and had megacycles install 256 rods. Since the 447 engine has a different number of teeth for the cam chain I used their adapter so I could use the 72 cam with the 447 sprocket. I didn't have a 447 sprocket to press on the cam. In retrospect to would have been easier. With the megacycle set up I had to dial in the cam. Well the engine ran well but it was a bear to kick start, I knew I was off a bit on the cam. If you weren't careful it would brake your leg if it kicked back so I relied on the starter. So I decided to correct the timing issue since I was also converting to a vape system . I was off over 1/2 tooth on the cam sprocket so maybe 5 degrees. So for 3 days, 8-12 hours per day I got everything moved over and cleaned and timing corrected. I also decided to install new tires. I also cleaned up a few things that had bothered me for the last 13 years. So now the bike starts on the first or second kick (the Vape system was very easy to set up and works great) and I can stay out of the hospital from a broken ankle.
I found some myshka chewings, I committed my first act of hamfisting whilst trying to remove the fuel tank![IMG_3491[1].JPG IMG_3491[1].JPG](https://www.xs650.com/data/attachments/361/361216-e69433196067f2c372d723baaadab039.jpg)
You know I really need to look up the origins of that phrase as I have been asked if it is fisting ham or hamming fist after having used it in conversation. My renter has a pretty twisted imagination.![IMG_3514[2].JPG IMG_3514[2].JPG](https://www.xs650.com/data/attachments/361/361220-2d73d99cd6e5db62ff33dee3ee97789f.jpg)
I picked the cheapest one with the best reviews but didn't realize that it wasn't an actual camera like others hence the phone pics. Still pretty cool.![IMG_3516[1].JPG IMG_3516[1].JPG](https://www.xs650.com/data/attachments/361/361222-87a82a1d4c3901a56c2f97e9d448c9e3.jpg)
![IMG_3518[1].JPG IMG_3518[1].JPG](https://www.xs650.com/data/attachments/361/361223-5d7a7576201c44efdac41e1e955d450d.jpg)
![IMG_3524[1].JPG IMG_3524[1].JPG](https://www.xs650.com/data/attachments/361/361224-6c22c68c40ec91cec6a4d0392586522b.jpg)
The down tubes were not to bad but noticeable if you really looked , I filled them in with a bit of weld before powder coating the frame. I have had a few frame from other bikes where the gorilla really tightened them down. Never liked that look of those bars but when I was working in the custom shop back in the 70's we sold a ton of them with those cheap cast foot pegs.Just cleaned up a few things? Gave it a quick tidy, spit shine? Well you don't mess around, nice job. So how bad were the downtubes damaged? I am assuming the highway bars were those ones that clamp on with U-bolts and I only ask because I was about to mount some old ones I had from a basket case I bought years ago. I was going to try to use them as a jack point to lift the front tire off the ground as anything aft of that raises the rear tire and now I'm thinking that's probably not a very good ideah. So do you have any pics of the tubes?
What do politicians know? Some stuff, I’m sure. Certainly nothing about the rules they impose upon us.Something which the people who live in these deserted village streets dont fully comprehend its that my bike is noisier for longer and creates more air polution at 20mph than 30 mph.
. . . In various areas of UK, people are having the speed limit set to 20mph . . .
I sure wish someone repopped the panel overlay
That's because the other allen bolt was in the process of being ground and polished when I took the pic. The bike was a bit of a mashup when I bought it, it took me a while to sort out things like the rear signal mounts (didn't have 'em, lights were attached through the rear fender mounts), and it had the wrong side stand. As far as the overlay, I actually bought the exact repop shown w/o noticing it was for the RD250/350, it looks great, but it doesn't quite fit my gauge cluster. Sounds like I should dig it out and compare some measurements to what is provided here, and see if we can determine exactly what is what. I was sorely disappointed when the repop simply would not fit- that's when I looked harder and saw it was for the RD series on the web site. This is good stuff- knowledge of the most arcane of details is how we gain our expertise. My true expertise is AMC/Rambler from '65-'70- I can look at any specimen and know what is right and "wrong" with it- I'm not to that point on these XS/TX bikes yet, having only owned one so far.View attachment 368853
You do not have a 74 TX650 gauge cluster. You have a 1973-1975 RD250/350 gauge cluster.
The tell is the distance between those bottom two red indicator lights. The center-to-center lens distance on a 1973-1975 RD250/350 cluster is 38mm. The c-to-c distance on a 1974 TX650/1975 XS650 is 44mm.
Also, the tach red line on a 1973-1975 RD250/350 is 8.5K. The tach red line on all XS650s is 7.5K.
They do not make repop gauge faceplates for the 1974 TX650/1975 XS650. However, you can buy a RD250/350 face plate that will fit your current gauge cluster here:
https://hvccycle.net/yamaha-rd250-rd350-1973-1975-ignition-trim-plate-hvc20087-9-360-83519-41-98/
Of course, the "High Beam" label is wrong. For a 74 TX650 that indicator's label should be "Brake Lining."
One more thing. Your entire gauge bracket appears to be held on by a single allen bolt. That's a lot of cantilevered weight for a single fastener.
Yes, I would really like to know what the fitment issue is. Please let me know, thanks.I actually bought the exact repop shown w/o noticing it was for the RD250/350, it looks great, but it doesn't quite fit my gauge cluster.
So- as noted, the bike was a bit of a mashup when I got it in 2013. I just recollected that it had a small headlight, which I later learned was likely RD. The proper bucket fit much better. But- the small headlight tracks with your observation about the gauges being RD. As to the aftermarket RD(?) overlay I have, the distance center to center for the lower warning lights is 1 3/4" roughly. The center to center distance on my gauge set is 1 7/16" roughly. No fit my gauges. Also, note my repop has the "Brake lining" light rather than the "High Beam" lettering shown on your example. Finally, on my cluster, the "High beam" light is lower left, "Brake Lining" is lower right. I bought the repop overlay 13 years ago, memories are hazy.Yes, I would really like to know what the fitment issue is. Please let me know, thanks.
