Just a little before/after shot of my nasty old rear shocks. Or should I say after/before...
https://www.mikuni-topham.de/
Heiden tuning ? You have also a Heiden sidecover ?
There's parts I wanted for this order that Heiden Tuning don't sell. Same with Yambits in the UK. They don't keep parts I needed.
Now that Allen's Performance are gone, there's possibly a business opportunity in the UK. But it's so difficult to run a small business now here, I doubt anyone will try.
Yes, my buddy had a set of those shorty megaphones and replaced them for the same reason, lol. He's running the Commandos now and it's all good .....
for a cheap fix I bought an FMF universal muffler packing kit for about 30 bucks pulled the cones and baffle tubes out wrapped 1/2 the packing around each core secured it some masking tape then wrapped the packing in Stnlss wire. Cut a couple of pices of steel screen in circles to pop in before putting the reverse cones back on. It doesn't draw looks from the local Gendarmes .
Brakes okay but need adjusted...rear getting over it's slight drag issue (shoe/drum concentricity) but needs tightening up, front needs lever travel adjusted so it starts to bite earlier.
Adjusted the front brake lever and (again) did the little overnight clamp-the-lever trick to - theoretically - allow micro bubbles to rise up and out. Lever travel now much reduced and super firm. Happy! And this with the slightly more compressible DOT 5 fluid.
I think the rear brake will need a few rounds of significant cycling and further adjustment to finally bed the new Ferodo shoes and gain good stopping power (or at least as good as it will get🙄). Also think I will need to clock the brake arm at least one spline clockwise.
one of the best ideas for bleeding is the "Stahlbus" Valve ... its almost the expensivest Way :)
https://www.stahlbus.de/entluftungssystem/entluftungsventile/konisch-dichtend-standardbauform/
I made this Valve by myselve from a genuine bleedingbold:35232716-6295-4F5B-B950-9160F1820A38.jpeg
On the other Hand there is a DIY Methode with a Plastic-hose where you press a bicycletirevalve in. A small O-Ring around the bleederbold seals the M8 thread to prevent air sucks back in. So it is done in a couple of minutes...
btw:
https://www.xs650.de/forum/viewtopic.php?p=302718#p302718
I made this Valve by myselve from a genuine bleedingbold:View attachment 372260
btw:
US version...
https://www.speedbleeder.com/
Rotor upgrade. The old one is 3kg. The EBC “vintage” is 1.7kg.
Nice upgrade! I chose to just resurface and drill my stock XS rotor, but for my ongoing KZ project, bought an EBC Vintage disc similar to that. My KZ won't be at a rideable point for a while, I'd love to know what you think about yours on the road?
