Swapped my tank badges today to troll my neighbor a bit. He’a got a Triumph that needs to be put back together, I’ve got a 650 that rides😎
That gave me an ideah IMG_3956[1].JPG nothing is sacred. If only it would have fit over the elephant ears
I walked around them, thought about Ruby's brakes but no, Looked and Mallory and shuddered. gathered parts and tools laying around from the last time I worked on then changed my mind. I picked up a "parts lot" a few months back for a buck fiddy which ended up being almost an entire bike so I decided to roll that out and give it a look see. I believe, if I decoded the vin correct, that it's a 79 special and all the tabs are still on it. The guy had planned to chop it but lost interest. It had a baby blue sportster tank and outrageous looking 16" ape hangers installed on a peculiar looking front end. One of yous (I think it might have been Gary) determined that the forks were from a tx500 as was the rear wheel. So I took the tank and side covers from my 77 (which I did chop) and saw how it would look.IMG_3952[1].JPG the side covers don't exactly fit right and the tank seems massive but not too bad IMO. Oh and the swingarm is from the 77 too, this one has a rear drum so that worked out. He had the regular Special wheel and arm installed and the tx wheel was with the other parts. So now I got a roller with a rear brake and the wheels match. Oh and a coat hanger I made out of those apes
Good job!
Obie and a crew of police officers from the surrounding areas collected extensive forensic evidence of the litter, including "twenty-seven 8-by-10 color glossy photographs with circles and arrows and a paragraph on the back of each one explaining what each one was, to be used as evidence against us"
But it was a case of American blind justice.
I find proper tire lube inside and outside the bead (double the amount you think is enough), along with a tire which has been out in the sun is what works. I’ve never had one not seat correctly doing it with those two requirements fulfilled.
Some progress on the wife's new bike thanks to (Halfmile) -Phil
I'm not entirely sure I understand. I would measure the shocks on the bike, measuring from the centre of the top nut to the centre of the bottom bolt. HTH.
This is exactly what I mean - I am considering ordering replacements, and I have not gotten serious enough yet to figure out how to measure. I saw your post and asked away. Center to center - got it! Thanks.
32 to 32.5cm centre to centre, measured with a steel tape hence the not exact dimension. Hope that helps.
