First startup after top-end rebuild - new rings, de-glazed cylinders, new cam chain, new valve stem seals. Ran around the block. Something is a bit off with fuelling to the rh cylinder just at idle, but no smoke, nasty noises or leaks, so this one can go in the Win column. :)
Have you ever tried a can of Yamaha Combustion Chamber Cleaner ? Aerosol can. One takes off the airfilters,fires up the bike hold the throttle at about 2,500-rpm spray it in the intakes until the bike almost stalls , then add a bit more and kill the engine. Let it soak in for the prescribed time go for a 20 min ride. then an oil and filter change must be done. I've done it to my XS and went one step further.After shutoff pulled both plugs and gave the piston crowns
another shot then re torque the plugs. Did the 20 min ride oil/filetr change. bike ran much better after wards. Also makes the best carb jets and passage way
cleaner I've discovered.
I had never even heard of the Yamaha Combustion Chamber Cleaner... I have heard of and done similar treatments with other petroleum products. The catch here is that I would have to make the engine run first. Recall that it came from a bike that appears to have burned to the ground. At the very least, it will need to have the cam chain tensioner, crankcase breather, stator and rotor, points, carbs and inlets etc replaced before one could attempt to run it.
Hi Judd, welcome to the madhouse - as you probably know best place for everything XS. You said just started but looks like you're well on the way with your tracker - why not start a thread to keep us all posted? Put plenty photos and ask as many questions as you like. What are the USDs off?
Cheers, Raymond
:agree: ... I'll follow for sure. Interesting assemblage of bits you have going there. I share Adamc's enthusiasm for trackers. I am building a tracker/scrambler as well under the Project XS thread.
Ok, starting on piston replacement (my first) looks like someone stuck a screwdriver through the plug hole and turned it over to find tdc is my guess. any suggestions or recommendations for this old newbie would be appreciated; In all the years I've ridden an XS 650 I've never had to go into an engine until now; but like a friend of mine in the port-a-let business... I will not be deturd(sp?)
Eventually tracked this to pilot jet / carb passages after checking and rechecking many things...I'm hoping for a better night's sleep with it resolved.
Taffy Tank Leaks Again........
Any of you fine brethren have experiance of the product below?
I'm considering buying some in from the USA suppliers.
Would one quart be enough for one tank?
Taffy's fuel tank has started to dribble again :(, so Im resigned to a tank seal fix.
See Mailman's adventures with that product. :(
Caswell seems to be the preferred brand everyone goes with now days.
My experience with Red-Kote. This was applied by a professional. I only use Caswell now.
Yes redcoat sucks but so far so good in several tanks with POR15.
I have done three tanks with POR15. All still holding up fine.
I need to edit my response about sealing the three tanks. None of the tanks had leaks. They were rusty inside. I used the POR15 system for cleaning the tanks, then coated them with the sealer.
Only drawback I've heard about Caswell prep is fiberglass tanks and having already had fuel in them.
Fuel leaches into the fiberglass and makes it harder to adhere once the tanks been used. Better to let it air a while first.
Virgin tanks seal the best according to fiberglass sellers.
Iff'n I was gonna use a tank liner (I won't, but if....) I'd prolly go with Caswell. I've read too many horror stories about Red-Kote.
:agree: ... I just think its a horrible idea. If you're trying to save a tank that is essentially porous due to rust, OK, if you really have to. If you have a leak or two, find it/them and patch with a durable metal repair; weld, braze or solder.
Perish the thought! See my response to @Jim's comment...
You need a product called Flowliner. I guarantee you it works. I did quite a bit of research into ethanol resitant coatings before committing to one. The best choice appears to be novalac epoxy coating. I had access to materials engineers and coatings specialists at work before I chose a coating system and that's what I concluded.
You only get one chance to do this and if I were you I'd speak to Jim Boulby about it. He's done several for me and friends. I think I mentioned him to you before.
This -
https://cwylde.co.uk/product/flowli...t-for-all-metal-fibreglass-and-plastic-tanks/
As usual, preparation is 90% of a successful job.
Sounds like just as well you asked . . .
