^^^^^for some reason, I don't think that is what the problem is...
Saul Good man. I feel your pain.I rebuilt a set of forks for the first time a few weeks ago, it was a dirty job but now they feel much better and actually might act like a real suspension. I decided to mount the tubes back on the bike and got everything torqued down, in order, was looking to align the front tire and then I saw it.
Funny you should mention carbs, I found the black plastic piece that goes over the pilot jet on my recent rebuild, I'm wondering how hard it would be to pull the bowls and install it but not sure which carb it's off. When I re installed them I thought it might be easier to do with the carb manifolds attached to the carbs, I was wrong. I end up doing the same thing with the acorn nut but only after attempting to remove with the top brace on, the throttle bracket on, the clutch cable in the way, the breather hose in the way, all because I think it will be quicker. Live and learn then forget, curse and learn again. One day I'll be retired and might finish a project, I've had that chopper since 2009 so There's no rush. The carbs were from another bike I picked up that "Ran when parked" when I replaced the petcock they leaked out the intakes, rebuilt and they held gas on the bench so we'll see. I looked for a thread that was about common F#ck ups and things missed by rookies but didn't find one. I laugh at myself but that's after cursingSaul Good man. I feel your pain.
In my younger years, I'd have cursed. Now I just take a breath and say, welp, gotta take care of that.
I forgot to mention in my post above that I put the carb back in, put gas in the tank, then turned around and looked at my table to see one of the Mikuni springs for the diaphragm. Was not so bad cause that can be put back w/o pulling the carbs, just gotta pull the tank.
I gotta enjoy the weather so while working from home, took a long lunch and did 45 miles of back country roads.
Tonight, I fixed the Neutral light that was just an oily screw to the switch. When pulling carbs, I pull the acorn nut off the chain tensioner to make more room and some oil dripped down I guess. Pulled the screw and hit it with contact cleaner on a pipe cleaner into the switch screw hole and then contact cleaned the screw and wire connection. All good now.
Thanks I will definitely look into it, I was in the process of trying to align the front end when I noticed the missing fork boot, I did take the pic with a phone camera which loves to distort images especially on the edges of the picFrom the pic, it looks like your forks and front wheel are off center to the rest of the bike. Probably due to the steering head bent. Previous accident? A good way to check is to take off the forks and triple tree and then stick a long broom handle through the steering head and see how the alignment looks then. It will show if the steering head or frame is bent. You can easily replace the frame. Lots of them around.
Only a year ? So it's RUSH job then ?Sounds like a threesome of hoarders here at least. Yes and it is a nice tank, two minor dents, the red with white stripes was still under that thick layer of black. The lack of better pics and no set freight charge scared off buyers I think. I'm chasing my tail trying to decide to keep working on the 71 or use the best possible parts and put a 70 together, then do a 71. I have the paint done for the 70 and the 71 paint is still just a painters promise to "get to it". And we know what painters time promises are worth. I'm coming up on a year waiting for 72 paint to be done.
The aftermarket sellers often supply nitrile oil seals and O rings as camshaft seals. They're not really up to it. The temperature up there at the top of the engine kills off nitrile seals. Like you, I use the Yamaha seals and the orange O rings, both are still available.Replaced the left hand side camshaft oil seal. After 8K miles from the top-end rebuild, the seal sprung a leak. It is a 7.5mm thick seal from a Mike's XS kit. After 3 years it became very stiff. The O-ring for the cover that came from the same kit was squared off and stiff as well. Replaced both with OEM parts. The green gasket was a pain to peel off. Made a replacement from a sheet of FelPro. FelPro always seals and comes off nicely. See the photo of the seal below. I don't recommend using this make.
At least it was not blown all over the battery compartment while dripping down belowNo excuses now, retired… let’s get this engine properly cleaned and back in!!! I’m pretty gearing up oil was used as chain lube and now has turned into almost solid paste![]()
Ditto. That stuff stuff does a good job and looks to me like it’s harmless to the aluminum and the paint applied to it.I have to recommend this. GUNK Engine degreaser and a good wash. It works.![]()
And the great thing about Gunk is the smell. Git yer engine nice and clean. Then, first set of traffic lights, that unmistakable aroma wafts up. Lovely.Ditto. That stuff stuff does a good job and looks to me like it’s harmless to the aluminum and the paint applied to it.
Does it still smell like it did in the 1970s?And the great thing about Gunk is the smell. Git yer engine nice and clean. Then, first set of traffic lights, that unmistakable aroma wafts up. Lovely.
Jezuz That could be the recipe for a REAL Man's aftershave !Does it still smell like it did in the 1970s?
The smell of gunk and red Hermatite, forever etched in my memory. I can smell it now if I think about it.
Gunk even had trouble with this mess but making clear progress today. Needs a day of fine detail now. Drained the oil and put it on its side for the bottom, next step - needs to come off this stand and lay down to properly get the bottom. Gunk I have disappointedly smells like citrusJezuz That could be the recipe for a REAL Man's aftershave !
That's certainly not how I remember Gunk?Gunk even had trouble with this mess but making clear progress today. Needs a day of fine detail now. Drained the oil and put it on its side for the bottom, next step - needs to come off this stand and lay down to properly get the bottom. Gunk I have disappointedly smells like citrus![]()
