Well, that happens when the lower was clamped in a vice and is now oval inside instead of round, lol. We had to replace one of the lowers on my buddy's '80 SPII because of this.
Well that would be bad news, but could explain what’s happening. When working on the forks, I never clamped the lower like that, but that’s not to say the po might have done itWell, that happens when the lower was clamped in a vice and is now oval inside instead of round, lol. We had to replace one of the lowers on my buddy's '80 SPII because of this.
I think I know the answer on this one.Well I got my seals today. They went into the lower tubes with old moderate bashing. They were most likely looser fitting than before since I cleaned up the bores where the seals sit. The first fork assembled well and I filled it with the appropriate amount of oil (15W this time), added the spring and mounted it on the bike. I assembled the second fork and the inner tube slid up and down smoothly, but when fully collapsed, with no spring, the inner tube gets “stuck” in the collapsed position. With a bit of tugging it would come free but when I went to fill it with oil and tried moving the tube, it was stuck in the collapsed position and no amount of tugging would free it up. I dissembled everything and couldn’t find anything out of the norm.
I know that in real riding conditions, the fork tube would never be this far collapsed with the spring in it, but I’d still like to figure out what’s causing this. Has anyone else experienced this and figured out why it’s happening?
New phone and camera coming soon. The wobble is driving me nuts.
Thx. Is the correct torque for the bottom bolt 14.5 ftlbs?I think I know the answer on this one.
the aluminum "Bumpstop" with inner taper isn't aligned with the damper rod. Have had it happen before, loosen bottom bolt with fork cap off, drop the tube, snug the bolt, a battery impact driver is helpful here, then assemble and finish torque, see if that "fixes" it. This is hard to do if there is old locktite on the bolt....
Or two oogy doogies. ;✓}Thx. Is the correct torque for the bottom bolt 14.5 ftlbs?
It's a taper? wider end down.wider opening at the retaining clip (B) or with the shouldered end at the retaining clip (A)? I had it assembled in config (A). In this configuration, the tapered aluminum end of the damper rod wedges itself into the piston. In configuration (A), the aluminum piece slides inside the piston.
Looks like the piston may have been assembled incorrectly. Don’t know if this was the work of the po or myself. Just trying to verify correct orientation of pieces.Excellent sleuthing there, lol. Nicely done, and I'll have to remember to watch for that.
Got it, thanks! I’m thankful I made a nice holding tool for the damper rod. Makes re/re the bottom fork bolt a breeze.Sorry for the delay.
34mm seals on 35mm forks?Any thoughts?
