I'm thinking the dust boots are your problem. I've had issues with 34mm boots just falling apart. Bad or non existent vulcanizing? Once that rubber gets smeared on the tubes, it gets down to the seals and mucks up the sealing. Bummer dood. looks like they are coming apart (again). Doncha just love redoing work cuz of defective brand new parts?
I would not buy "Yamaha" seals they don't make seals, just add a couple layers of markup to whoever manufacturers the seals. 50 years on they are using "meets spec" venders, not necessarily the company that built the seals that went in the bikes when new. Does Yamaha have higher engineering specs than All Balls? prolly. The good news is seals are pretty standard, so about every 34mm fork uses seals with all the same dimensions. Fresh stock is easy to find.
I've done pretty good with pyramid brand seals (parts) They are not expensive. My go to is dusting/coating the just out of the box dry seals with titanium dioxide before any grease or lube. That stuff has a high affinity for rubber and turns it silver. then lithium paste type grease between the lips before assembly. Usually have to wipe off some grease a time or few after riding.
Honestly I've got several tubs of tan lithium grease but still not the "paste type" of my dreams.....
