I think we’re looking at nearly 50 year old brake lines on this bike. Pads for now, yes.
Be aware that the stock fender has an inner steel hoop that helps stabilize the (as previously mentioned) noodlie fork tubes. No aftermarket fender will have that stiffener. Don't go backward on fork stiffness, flex.I will definitley be replacing the front fender with something shorter.
This is a really great point. You will notice in this photo previously posted by @jetmechmarty that the shorty fender is augmented by a brace as well.Be aware that the stock fender has an inner steel hoop that helps stabilize the (as previously mentioned) noodlie fork tubes. No aftermarket fender will have that stiffener. Don't go backward on fork stiffness, flex.
Another front brake improvement you could make would be to install a smaller diameter master cylinder...there are many discussions about this on this forum, but basically, the stock unit disadvantages you in terms of mechanical (hydraulic) ratio and feel. Many people have used and recommended a MC from a Yamaha TTR125 or TW200 to get an 11mm diameter unit AND provisions for the brake switch and mirror mount.I agree with the sentiments expressed by many others i.e. the bike is cool as-is, but would benefit from your planned mods...front fender, fork ears / headlight mounting, aso.
And obviously brakes are important and your systems are old. At minimum, I would: drain and clean the master cylinders, flush both systems very well with new fluid, and replace pads with new EBC, Ferodo, etc. I would also seriously consider jettisoning your ~50 yoa rubber brake lines for new braided lines...I've had great luck on 5+ bikes with these guys:
https://spieglerusa.com/brakes/brake-lines-accessories-tools/cycle-brake-line-kits.html
To carry it a step further, you could send your discs to Tom and get them resurfaced and drilled. This would enhance performance and reduce unsprung weight a tiny bit.
https://truedisk.net/
And finally, if it were me, I would (eventually) rebuild your master cylinders and calipers. Again, I've had good success here:
https://brakecrafters.com/
I love the look of the Smiths clocksView attachment 378916
Dual discs, small indicators, no fork covers, wire headlight ears, and I believe the clocks are deleted.
The Yu SR500 has small Smiths clocks in black cans. That works too. She also has a Lucas headlight.
11 mm M/C definitely!!! Going "cafe" is a commitment. Sit on the bike, feet on pegs ,and move your hands down to an imagined "cafe" position and you will find yourself in a posture that is less than ideal. I have moved my pegs back approximately 7 inches (mid sets) on one of my bikes and putting your feet below your body is a great improvement.
I personally keep as standard as possible, be worth more in future. The bike is 50yrs enjoy the rides.Hi there,
I bought a 1977 XS650 Special about two years ago while I was still in college. The bike ran, but it had some electrical issues that needed to be addressed. I figured I could handle the work myself, but quickly learned otherwise. I eventually realized it needed to go to a professional, but being a broke college student, I didn’t have the money to get it fixed, so it ended up sitting for nearly two years.
Last week, I finally took it to Limey Bikes in Austin, where they replaced the entire wiring harness, tuned the bike, and worked through most of the other little gremlins. It’s running great now, and I’m finally at the point where I can ride it to work!
Now that I’m out of college, working full-time, and able to put some money into the bike, I’m looking to start making some changes. I really like the cafe racer builds I see on this page, and I think the XS650 is a great platform for one.
I’d love to hear what you guys would do if you were in my shoes. What changes would you make first, and what are some relatively straightforward ways to improve the overall look of this particular bike? I’m open to recommendations on everything , but I’d like to approach it in a way that makes sense rather than going into it blindly.
Thanks in advance for any advice!
^^^^ All very good comments, info, esp videos for brake bleeding. For much more brake info, follow the link below to the tech section on this site...scroll down to "Brakes":I'll just add a caveat - I said it's very doable, and it is, but brakes are a safety item so you must get it right. If you replace the brake lines and the master cylinder, you need to bleed the new fluid through the system until there's no more bubbles coming out from the caliper. If there's any air left in the system, you brakes will feel 'spongy' - worst case you'll be able to pull the lever right back to the bar and you should not ride the bike like that.
Oh, and for tools I mentioned a spanner for the bleed nipple - you'll need a screwdriver to take the lid off the master cylinder, and 13mm spanners if you replace the lines. Get yourself a JIS (Japanese Industry Standard) screwdriver to avoid striping screws. Bleeding brakes just needs a bit of care and sometimes patience to get the bubbles out. Can give more advice on the procedure if needed but you could watch a youtube video?
I must confess, I have never seen this...thanks!! The next brake I will be doing is not XS, but procedure will transport perfectly and I will use it!Read here on "you gotta" front brake overhauls and getting back to a "no air" brake system..
https://www.xs650.com/threads/rebuild-front-brake-need-to-bleed-it-nope.58245/
