RobXS650
Fellow XS’ers!
First off, thank you again for the warm welcome the other day. Nice to know there’s a place for people like us. ‘Voor elke gek, een plek!’
Like the saying in Dutch goes.
I’ve been puzzling over something for days and can’t figure out the best approach. So, once again, I return to drink from your well of infinite knowledge (and patience)!
The fact that I’m redoing the wiring (Wiring XS650 1979) isn’t exactly for fun. The problem started like this: after connecting the VM34 carbs and especially after syncing them, I drained the battery and had to recharge it. As you might have noticed the other day, the battery is tucked away in a well-hidden battery box with two switches: on/off and one for the lights. After charging, I briefly tested if the lights worked (with cover and the switches slightly off the bike) and accidentally touched something on the frame (I think), causing a short circuit.
Red wire and red/white wire seem burnt
I see two slightly burnt wires under the on/off switch. According to the wiring diagram I made, it’s the red wire (which goes with a fuse to the battery and the stator) and the red/white wire (which goes to the Newtronic electronic ignition), both coming out of the on/off switch.
Red/white to Newtronic (inside looks old and painted with some protective stuff, but seems fine?)
Now the choice is... to either rewire the old system, connect everything, and hope for the best...
Or, since I’m already working on the electrics and have everything open (and I need an new excuse to spend time in the shed this winter
), buy a new ignition system.
In that case, I’d likely go for the Boyer, combined with a new reg/rec. Apparently it is better for all systems involved to upgrade to reg/rec in one, when using the Boyer set.
I also can’t find any info online on the Newtronic black box, to replace it or how to test it (for example, how to measure the inner workings?!) without the engine running or powering up the electronic ignition.
I’m still learning about this (electronic) stuff, and I don’t want to damage other components by just hooking it all up and testing it.
Normally I’m pretty self-sufficient, so I won’t be posting questions like these on a regular basis. But like I said, I don’t want to do something stupid (again) and end up with an even bigger problem.
By the way, I’d rather not spend €236 + €104 on a Boyer and new reg/rec unless it’s really worth it, especially in the long run.
What to do, what to do?
- Boyer cdi 236€: https://www.heidentuning.com/xs650-...dware/ignition-cdi-boyer-bransden-detail.html
- Reg/rec 104€: https://www.carmo.nl/index.php?main...C0ToQAvD_BwE&zenid=o57lkurvejg3cbq1o156ejvud7
