What's wrong with my left hand carburettor?
this old xs
Australia
Hello brains trust, 1978 Special, stock except mufflers, carbs have been rebuilt a couple of years ago. So the bike got really hard to start cold, hot starts no problems. I went right through everything, valve clearances, points gap, timing, cleaned carbs, pilot jets etc etc. Cold starting is now back about where it should be which is nice, runs great and pulls very nicely. I had the carbs off last Friday and everything looked perfect.
But... I did a Dogbunny carb sync as the right hand cylinder exhaust pulse was a lot weaker than the left hand cylinder and here's where the problem shows up. To get the pulses equal, the bike idles at about 1500rpm with no contact from the idle stop screw. The throttle cable is slack, I can't get it to close any further i.e. the left butterfly must be fully shut? I got it so the exhaust pulses are pretty close, but the idle screw is only just barely touching the throttle.
The other screwy thing with the left hand carb is that turning the mixture screw does basically nothing. I can screw it all the way in and the bike idles fine, right hand carb you can hear it change rpm after about 3/4 turn. On the left hand carb I actually removed the mix screw while it was idling just to see what would happen. After a second or two it did stall and cough out the mix screw hole, but geez!
To my way of thinking the bike must be getting some air/fuel (not just air, intake boot is only a couple of years old, vacuum port for fuel tap is filled with solder, plug is black when pulled after messing around trying to sync carbs - so idling for ages), but where from?? The only place I can think of is maybe the oring for the jet needle, but I dunno, doesn't seem very likely to me.
Definitely open to suggestions.
Definitely not part of the brain trust but I'll play. Improper float level can make mix screws infective. Doesn't sound that likely if the bike ran well before. Hard starting could point to idle circuit, sure that was clean. O ring intact. New intake boots have been known to fail. Check for vacuum leaks. BS 34s on 78 Special? Good luck. Keep us posted . We love a good caper.
Oh, pics of your bike.
My ideas:
Next time you take the carbs off, take some pics of the butterfly’s on both sides, closed and open. A couple pics of inside the float bowls possibly. Maybe there’s something off about them we can see.
Maybe try swapping the idle jet and idle mix needles from One side to the other.
Definitely check for vacuum leaks
Thanks for the suggestions everyone. Will have another look either tonight after work or tomorrow and try to get some photos. Float height 24mm, checked recently.
Here it is after I just fitted a Dart fly screen. Needs a wash badly!
Curious to know if there is any noticeable effect from the small screen at freeway speeds, if you've had a chance to try it out.
The screen is fantastic, I'm very happy with it. I can definitely feel the difference. I had a Puig screen on there but it was for 8" lights and I didn't really like the look of it, plus it would gradually lean back over time under wind pressure. But when I took it off I sure missed the wind protection!
The Dart fly screen deflects the wind somewhere around my chin, which works well for me. I'm just under 6'. Great in the rain too.
I bought the one for an SR400 as they don't list one for the XS650 but I recently bought a 1979 SR500 and there's a few common parts so I took a gamble. I had to drill out the bracket mounting hole because I don't have OEM indicators, but if you did, I believe it would bolt straight on.
After commuting today, I'm definitely thinking it must be just a plain old vacuum leak somewhere. I adjusted both mixture screws in 1/2 a turn from factory (2 1/4 turns out, so now 1 3/4) and now I get some good popping on the left exhaust. Also the idle will race to 1500 then after quite a few seconds it will settle to 1100. This has vacuum leak written all over it.
A couple of years ago I replaced the butterfly shaft seals. I don't recall exactly but I think I ended up one short for some reason. I also vaguely recall thinking I better put the old seal in the place where you can get to it without splitting the carbs, which is the left outer end of the butterfly shaft. I'm pretty sure I saw a butterfly shaft seal the other day, so I'm going to start there.
Well boys, we cracked it. I yanked the carbs and as I suspected, the left butterfly was shut, right was open. Thinking on it, I began to suspect the enrichment circuit (technically not a choke, but I won't be that guy). Screws weren't loose but could be tighter, pulled it to bits, scraped the mating surfaces with a razor blade, in a move I almost certainly won't come to regret, I changed the plunger back to an old one and put it all back together gutentight.
While the carbs were off I synced them by eye and set a bit of idle purely guestimating it. Ho-lee! It lit right up and has never ran so smooth. Synced the carbs and she purrs like a kitten. Probably too rich as it doesn't need the choke, but future me can care about that if he wants.
Full disclosure - I have Honda CB250/350 mufflers on there that I randomly acquired and liked the look of. To get any sound I ended up completely gutting them and putting those ebay perforated tube baffles in. Sounds great. Anyway, the left muffler has been ticking at idle rather loudly but I couldn't remember if it has always been like that, or maybe it was just the way the gas was going through the shattered remains of the oem baffles or something. Nope, clearly it was a vacuum leak. I've had chirping at the carb for a vacuum leak, but the ticking exhaust was a new one for me. There still is an occasional tick but I'm going to ignore it for now.
