Why did I wait so long??!
@Mailman 's thread on Boyer installation is pure gold to me I wanna tell you!
I'm scratching my head here trying to figure where I want to set my total timing (advanced) when my new Boyer plate gets here tomorrow since everything else is done and ready.
I read the references to 35 degrees instead of 40 (and why) and I'm sold, 35's where I'm setting mine.
So I wonder what reference point to use?
Bam, few pages later in Mailman's post...there it is. Credit to @Jim for pointing out to use the right side of drain slot as a 35 degree reference.
Man....I love this forum, pure gold I tell you. 🥰
Well, I puzzled over how to mount the Boyer coil set up for a good while because on the 75's that huge flasher unit hangs right in the open space between frame back bones. Just as I was considering lopping it off with my angle grinder I had an epiphany to cut only the bottom 1/4 off of it after straightening it. Then I could use it as a good, central mounting point for the Boyer coil pack.
After making a small plate, getting some spacers and metric fasteners (I cant mix standard & metric on any bike!) it all went together very well.
Excellent. I wonder what the real story is behind the batch of bad ones? We'll never know, unfortunately.
They may be that way regularly and no one ever paid attention?
I was just making sure everything looked good on solder joints when I noticed how crooked they were.
Would it affect anything, I'm not certain? But when you pay for a product, you shouldnt have to use inferiorly assembled parts (in my opinion anyway).
I feel better knowing they're at 90 degree angles from the board now anyway. :thumbsup:
Well, if the pick ups aren't spaced at exactly 180 degrees, and those you had clearly weren't, then it's impossible to get correct timing on both cylinders.
These have been made pretty much this way since the late 1960s. I haven't ever heard of those issues with Boyer Bransden.
Happy that you're sorted. The BB ignition works just fine on my 650D.
Well, got carbs bolted back on, rebuilt petcocks again with genuine Yamaha 4 hole seals (this time!) and used Mikes XS gaskets on back of the petcocks and they actually worked, really well. Much thicker than all the other aftermarket offerings, nice for a change to get a good product from Mikes that I couldnt find anywhere else. :thumbsup:
Fired right up, hit it with a timing light to 35 degrees total advance (thanks Jim). Ran great, Boyer works awesome, voltage gauge works great...nice to watch voltage in real time all the time.
Only issue was with the carbies...again. Big part of reason I went down this slippery slope to begin with was the weird intermittent stalling when rolling to any sort of sudden stop. Also sometimes pop stalling at idle when stopping at stop signs. Then other times it would run ok, sort of....idle was never really at consistent RPM.
Cleaned carbs when I did the Boyer complete with ultrasonic bath, float settings, etc...
Still did the intermittent pop stalling, albeit not as bad this time. Re-read specs on these 75's. 3/4 turn standard fuel screw setting +/- 1/2! What a weird setting and plus or minus.
I was at 3/4, so I went up....much worse, idle all over the place. Went down to 1/2, better but an occasional pop stall still. Ok, they said +/- 1/2 turn, lets see what happens?
Went down to 1/4 out from seated and whoala, Bob's your Uncle. Its never idled and not popped so well. Settles into excellent tick over immediately no matter how abruptly I stop.
What a weird fuel mixture setting, never seen one that low and I've messed with a lot of em. Makes me tempted to put a leaner set of pilots in just to see if I'd get a normal range of settings out of the carbs? But then again, why if this is working so well, right? :shrug:
Anyway, time to put covers back on tomorrow, take a trip to the local non-ethanol gas station for some gas jug fill ups ($$$$!!) and do some extended riding tomorrow...supposed to be our last warm day of the year. :thumbsup:
Now that Ive run around with the Boyer for a little bit, I made a couple of shall we say "Spirited Runs" on it and I'm a little concerned I may not be jetted fat enough?
I installed Uni Filter 4200's at the same time I did the Commando mufflers.
I went up to 130 Mains from the original 127.5 Mains. Left the needles at stock setting (1 notch up from bottom).
I looked at the piston tops, didn't care for the chalky look on them...just a bit paranoid about holing a piston, left side a little more so than the right.
I would just go by the jetting thread but my 75 is kind of an oddball year in the jetting charts. Figured Id appeal to the masses and see what ya'all think?
I dont know much about carburetors or jetting But I think these are to pale to lean .This being a cooler time of year .Not sure how it is where you live
I would be nervous for what happens a warm day highway speed ..longer run .
Mine 1980 BS 34 at least burns the otherwise sooty plugs into brownish at that use ( warm days faster )
Not sure why but I would be nervous being to lean also.If they looked like that. And act But again I dont know much about jetting
Mine also runs with less vibrations with a bit richer mixture.
Maybe a tad lean... but doesn't actually look that bad.
Remember now, between about 1/4 to 3/4 throttle, you're livin' on the needle, not the main. So unless all that spirited time was at WOT... on the main, I'd leave it at 130 and raise the needle one notch. I'll bet it'll darken them plugs enough to make you happy.
Last point. The danger zone, is when you pull the plugs and see little bitty balls attached to the electrode and insulator. Them balls will be tiny bits of aluminum melted off the piston. Is that what I'm seeing here?
I think that maybe the PO's attempt at adjusting plug gap creating some marring/chafe marks, but Ill take another look just to be sure.
