Good point. The current literally pulls the chrome off. It's not entirely dependent on the acid.they reverse the electrolysis in the acid bath.
Usually dedicated tank just for the this process. dunno about what that does to aluminum.
Thanks for that.I thought I remembered something about acid removing chrome. I do not advocate anything, merely passing along what I read. The article talks about various methods.
Taken from this article,
https://www.china-machining.com/blog/how-to-remove-chrome-plating/#:~:text=Also known as muriatic acid,be enough to remove chrome.
I've had some very nice aluminum parts that had been plated.![]()
It has to be something I can do myself. And not overly complicated/dangerous/poisonous. The plate does not have to be perfect, I just have to at least get rid of the rough, blasted-looking finish.Good point. The current literally pulls the chrome off. It's not entirely dependent on the acid.
Just recalled... @Kevin Werner sent me the fenders off his red bike for paint last year. He had sent 'em out to the chromers and had 'em de-chromed. The surface of the steel was rough... very rough. You could tell the acid they used ate away some of it. It took extra coats of epoxy filler to get a paintable finish. My thought is if it'll do that to steel, aluminum likely don't stand a chance.
Don't know if that's representative of all chrome shops, but they did it to those.![]()
Just curious, what does SiC stand for?Three grades of SiC
https://www.google.com/search?q=sil...CDMwMjlqMGo0qAIAsAIB&sourceid=chrome&ie=UTF-8Just curious, what does SiC stand for?
Muriatic acid and hydrochloric acid are one in the same for all practical purposes.Years ago when my uncles business started removing rust from bathtubs they used muriatic acid and a HUGE problem was even the fumes would strip the chrome off the bathroom hardware (even stuff not in the tub). Now this wasn’t super nice triple plated car show chrome, but chrome nonetheless.
It may be worth a shot.
A little valve spring theory is in order methinks...I am finally putting the engine back together.
The following illustrates why I hate engine work. People with OCD (me), should not work on engines.
Preparing to install the valves. Take a quick look at Hans J. Pahl's book four tips. On page 103, at the top, it says "The inner and outer valve springs are installed in a certain orientation." Well, that's interesting. Never heard that before. Then, I take a look at the diagram, figure 7-50. Does this make sense to anyone? After much ruminating, I finally conclude that what the diagram is trying to say is that the END of the spring (my added red circle), is supposed to be clocked a certain way in the cylinder head.
Question: Has anyone ever, EVER, paid any attention to how they clocked their valve springs? OCD minds demand to know.
In an attempt to get some clarification on this, this video was the only thing I found. Which was no help at all. No mention of clocking the ends of the springs at all. Instead, the video states that the valve springs are progressive, and it makes a difference which end is up when you install them. Well guess what? I look at my valve springs, and they are NOT progressive. More confusion. After looking at part numbers, I finally conclude that 1970 to 1973 valve springs are not progressive. That didn't happen until 1974 or later.
BTW, no mention of progressive valve springs, nor which way is up in the Hans J. Pahl book.
And the slog continues...
I'm a little confused here... The inners and outers are wound in opposite directions... there is no way possible to install them and NOT have the windings spiral in opposite directions. Am I missing something?What I do is install the springs so that the inner and outer coil rotate opposite directions.
Okay, I like this. But, then, what in the world was Hans J. Pahl getting at with his diagram???As far as clocking, William, it doesn't matter in the least. Soon as that engine fires, the springs will start a slow rotation. All your hard work clocking 'em correctly will be for naught.
To be honest, I've no idea what he means. However you clock 'em, they won't stay that way for long. Even if they did, I can't think of a single reason why it would matter.Do the springs rotate as a pair, and always keep the same relationship to each other? Maybe what Pahl thinks is important is that the ends of the springs be clocked approximately 100 degree apart???
My bad. Funny how your mind thinks one thing, and your fingers type another...I'm a little confused here... The inners and outers are wound in opposite directions... there is no way possible to install them and NOT have the windings spiral in opposite directions. Am I missing something?
Okay, thanks again, great stuff.My bad. Funny how your mind thinks one thing, and your fingers type another...
I make sure the progressive coils are opposite. I put the tight winding down on the outer, and up on the inners.
In other words, as much as you can, make the outer and inner as different as possible so that hopefully, the resonance characteristics are different.
Okay, this bothered me so badly that I had to call 2M. I'm telling you when it comes to all things mechanical, that man has a mind like a steel trap. First off, he remembered this post by mrriggs:To be honest, I've no idea what he means. However you clock 'em, they won't stay that way for long. Even if they did, I can't think of a single reason why it would matter.![]()
As you said.However you clock 'em, they won't stay that way for long.
