Agreed. Yes maybe @Raymond will know or @Bob Wegman?AI might be wrong, but I'd give it if it were me. Worst case, you're already working on parts of the removal. Nothing ventured, nothing gained.
I missed that...how low is the compression?Yes there’s a gremlin in there that I need to find. The crappy compression numbers were an indicator that something isn’t right yet once running, it runs so well that I and all friends who ride it can’t believe the numbers can be that low. I’m looking forward to doing the leak down test later today.
Whatever the results, I have all winter to mess with it. I think the motor will be my first priority. No sense in spending time or money on something that doesn’t “run correctly”.
Trouble with this bike is I don’t want to drop too much money into it. The market for these bikes isn’t very strong so I’ll have to keep track of my costs to make sure I don’t go diwn a big rabbit hole.
If the top end needs refreshing it shouldn’t be too expensive.
Stay tuned for more exciting news!![]()
I actually can't. IIRC I rebuilt the engine on the 1979 SR500 five times and they were all engine out jobs. The first was when I did an oil change and found an engagement dog in the sump. I wuz an impecunious student and my pals advised 'refill the oil and sell it'. But I couldn't do that, so I heaved the engine out, stripped it, cooked it in the oven as prep for splitting the cases to get to the gearbox, replaced the broken third gear cog. That was my first ever 'engine rebuild', very methodical, all bits in plastic bags and labelled. Washed all the gearbox bits in a plastic dish-wash basin and found a thin shim which I couldn't work out where it came from. Went on one end of the layshaft, but which end? So i guessed and rebuilt the engine.Maybe @Raymond can shed some light?
Thanks for the info. Leak down test first. Then I’ll decide if a dismantling is in order.I actually can't. IIRC I rebuilt the engine on the 1979 SR500 five times and they were all engine out jobs. The first was when I did an oil change and found an engagement dog in the sump. I wuz an impecunious student and my pals advised 'refill the oil and sell it'. But I couldn't do that, so I heaved the engine out, stripped it, cooked it in the oven as prep for splitting the cases to get to the gearbox, replaced the broken third gear cog. That was my first ever 'engine rebuild', very methodical, all bits in plastic bags and labelled. Washed all the gearbox bits in a plastic dish-wash basin and found a thin shim which I couldn't work out where it came from. Went on one end of the layshaft, but which end? So i guessed and rebuilt the engine.
The gear-change was stiff-as-hell, so I must've guessed wrong. Stripped it all again, second time you know what yer doin. Did engine out, dismantled, cooked in the oven, shim swapped from one end to the other, rebuilt, lobbed back in the frame, and test ride all in one summer's day. That was my second ever engine rebuild. The gear-change reverted to normal, thankfully.
The other jobs were largely to do with 'rectifying' the tuning job - had to replace exhaust rocker after the pad was completely hollowed out, also had to replace one camshaft bearing, swapped the std camshaft back in, swapped the std piston back in, etc. I don't recall doing top end work with the engine still in the frame, but it was forty-odd years ago. But seat off, tank off, exhaust off, carb off don't take long, then it's one little engine mount and three bolts (?) and you can lift the engine out. Lot less heavy than an XS650 lump.
Not planning to do any engine work with the 1999 bike.
Iirc the best cold, dry reading I got was 90psi. Thats when my learned friends said no way after hearing and riding the bike around the block.I missed that...how low is the compression?
Although 90 psi isn't great, it doesn't explain the failure to stay running. I've had engines run easonably well with a weak cylinder like that. I doubt that any Briggs engine generates 90 psi!Iirc the best cold, dry reading I got was 90psi. Thats when my learned friends said no way after hearing and riding the bike around the block.
Had a DT250 ages ago that was completely wore out. When you kicked it, you couldn't feel any compression at all. Felt like the plug was removed. But if you ran and bump started it... and even that took two or three tries... it would fire up and run. Definitely weren't going racing with it, but it would still pop a wheelie in 1st.Although 90 psi isn't great, it doesn't explain the failure to stay running. I've had engines run easonably well with a weak cylinder like that. I doubt that any Briggs engine generates 90 psi!
Once started it has no problem staying running. Starting is the only issue. The stock carb on these bikes are apparently notorious for being temperamental. Once the cold weather sets in I’ll give it a real good cleaning. Right now it’s running on the carb as received from the po.Although 90 psi isn't great, it doesn't explain the failure to stay running. I've had engines run easonably well with a weak cylinder like that. I doubt that any Briggs engine generates 90 psi!
...Put the original jetting back in it including the needle position. I bought the 1st TT500 the Yamaha dealer got in 1976. Boulder, CO is a mile above sea level and I never changed the jetting from stock. Trail rode it for a year with no problems. I don't remember ever having trouble starting it. I also rode a new (250 mi)1979 TT500 down Baja from the Mexicali to Cabo and back up, mostly on dirt...the Baja 1000 was marked and we rode a lot of it stopping a lot of the time for pics and beverages over 2000 miles. I don't remember having trouble starting it. We didn't change the jetting then either.Interesting read Jim. Yes I don’t touch the throttle. Their starting procedure says push the white button. Marty also said he started his that way. I thought it was referred to as a warm start button but I’ll try using it first a cold start tomorrow. What it does is lift the slide a bit and provide more air and fuel for a fast idle.Just read a Cycle Magazine road test that said because the Mikuni carb has an accelerator pump, don't touch the throttle, as it's easily flooded.
Perhaps it's just that simple?
https://www.motorcyclespecs.co.za/model/yamaha/yamaha_sr500 78.htm
I need to check jet numbers and needle positions to make sure they’re stock. When I opened up the carb weeks ago I just checked cleanliness and float level. ThxMy...Put the original jetting back in it including the needle position. I bought the 1st TT500 the Yamaha dealer got in 1976. Boulder, CO is a mile above sea level and I never changed the jetting from stock. Trail rode it for a year with no problems. I don't remember ever having trouble starting it. I also rode a new (250 mi)1979 TT500 down Baja from the Mexicali to Cabo and back up, mostly on dirt...the Baja 1000 was marked and we rode a lot of it stopping a lot of the time for pics and beverages over 2000 miles. I don't remember having trouble starting it. We didn't change the jetting then either.
That's a good and fair test write-up, tells you what the SR is and is not. Back in the day, the UK m/c press didn't understand the bike and savaged it. Good discussion of the start procedure too.Just read a Cycle Magazine road test that said because the Mikuni carb has an accelerator pump, don't touch the throttle, as it's easily flooded.
